Removing Back to PineTab
Does the back of the PineTab just pop off like the back of the PinePhone ? I figured it best to ask before I try it as I don't see any noticible notch to pop off like the PinePhone has. I tried searching DuckDuckGo for breakdown guides but found none. I don't plan on any upgrades yet but want to add an M.2 SSD down the road so it will be good to figure out.
PinePhone BraveHeart Edition
Pinephone Convergence
PineTab
RockPro64
(09-11-2020, 08:14 PM)publiclewdness Wrote: Does the back of the PineTab just pop off like the back of the PinePhone ? I figured it best to ask before I try it as I don't see any noticible notch to pop off like the PinePhone has. I tried searching DuckDuckGo for breakdown guides but found none. I don't plan on any upgrades yet but want to add an M.2 SSD down the road so it will be good to figure out.
 You can remove it by inserting a fingernail (or plastic pick) at the corners, but it's much stiffer than the pinephone cover, and seems to be providing a lot of structural support to the unit. Replacing it is also quite tricky, especially around the magnet and pogo pin area, I had some internal issues to fix so took mine apart - the second time I broke the digitizer, so you probably want to avoid that.
Thanks for that. I was able to get it off and back on. I agree it was a pain to put back on.
PineTab
RockPro64
The PineTab back cover by design not intent to pop off.
might that not be an issue when the modem and nvme expansions become available?
I should rephrase my wording, the PineTab back cover by design not intent for frequent pop off. However, it is safe to pop off pinetab back cover to install expansion board and please watch out on the docking area which is a bit fragile due to thin plastic.
  Unknown Startup Password for Newly Delivered PINETAB-V - 10.1" 8GB/128GB krupine2 1 498 10-05-2026, 12:44 PM
  Not able to power on PineTab anymore zkajdan 4 6,215 01-12-2025, 10:38 PM
Last Post: vatin
Question Will Pinetab 2 spare parts be available? vatin 6 9,130 12-09-2023, 01:31 AM
  ?brighter screen replacement for pinetab (>1600 nits) dynobang 0 3,489 09-28-2023, 01:06 PM
Last Post: dynobang
  [Tutorial] How to overclock Pinetab 2 Darth-Apple 0 4,563 09-25-2023, 08:45 AM
Last Post: Darth-Apple
  External Reset button on PineTab V? michaelengel 0 3,110 09-18-2023, 06:31 AM
Last Post: michaelengel
  PineTab2 screen won't turn back on until reboot KelsonV 3 6,472 08-23-2023, 09:08 AM
Last Post: diederik
  Pinetab 2 screen no longer coming on Fibonacci 9 13,803 06-30-2023, 08:26 AM
Last Post: Purple_Illusion
  Pinetab completely bricked Saksmito 8 10,780 06-10-2023, 04:23 PM
Last Post: fxc
  What RISC-V chip will the PineTab-V use? msm 2 5,038 04-05-2023, 06:58 PM
Last Post: msm
