UPDATED (June 2021): 17-distro multi-boot image for Pinephone (incl. 3GiB variant)
(09-09-2020, 05:54 AM)nas Wrote:
(09-09-2020, 03:24 AM)megous Wrote: You're giving too little detail. This is just an image that's meant to be flashed to SD card and has everything setup already. No need to run p-boot-conf.
Yes, I should have been more clear: I was following the p-boot install instructions on the website before you posted this ready-made image. Nevermind, it's a bit off-topic for this thread and probably beyond my skill level.
You can check the scripts in the git repo. It's an example of how to install p-boot.
(09-09-2020, 12:18 PM)user_523916 Wrote: Thank you, very much for this. I'll try it as soon as i get my pinephone.
One question, could glodroid work with p-boot?
Apparently it is in a very rough state right now but it would like to try it out once it gets more polished.
I don't see why not. p-boot just loads the kernel and starts it.
I've dd or etchered this a few times now, and I can't get gparted or kde partition manager to resize the btrfs partition. There's always bad tree blocks during the partition check prior to resizing that error it. I've done a scrub on the mounted partition and it says it fixes errors, but still fails.
Any ideas how to expand this so the operating systems on the image don't die within a few minutes from disk space issues?
(09-09-2020, 11:50 PM)ikidd Wrote: I've dd or etchered this a few times now, and I can't get gparted or kde partition manager to resize the btrfs partition.  There's always bad tree blocks during the partition check prior to resizing that error it.  I've done a scrub on the mounted partition and it says it fixes errors, but still fails.
Let me try (you can of course do this from a PC using a SD card reader, just change the device from /dev/mmcblk0 to something else):
# resize partition, dry run
echo ", +" | sfdisk -n -N 2 /dev/mmcblk0
Quote:Disk /dev/mmcblk0: 29.74 GiB, 31914983424 bytes, 62333952 sectors
Disklabel type: dos
Disk identifier: 0x12345678
Old situation:
Device        Boot  Start      End  Sectors  Size Id Type
/dev/mmcblk0p1 *      8192  262143  253952  124M 83 Linux
/dev/mmcblk0p2      262144 15359999 15097856  7.2G 83 Linux
/dev/mmcblk0p2:
New situation:
Disklabel type: dos
/dev/mmcblk0p2      262144 62333951 62071808 29.6G 83 Linux
The partition table is unchanged (--no-act).
# verify changes look sane, and do a real resize
echo ", +" | sfdisk -N 2 /dev/mmcblk0
# resize filesystem
mount /dev/mmcblk0p2 /mnt
btrfs filesystem resize max /mnt
df -h
# /dev/mmcblk0p2  30G  6.6G  24G  23% /mnt
umount /mnt
# and that's all Smile
# btrfs check seems to succeeed without issues on the resized filesystem
btrfs check /dev/mmcblk0p2
Quote:Opening filesystem to check...
Checking filesystem on /dev/mmcblk0p2
UUID: 0cb50b0b-77a3-45bd-a605-857472b88281
[1/7] checking root items
[2/7] checking extents
[3/7] checking free space cache
[4/7] checking fs roots
[5/7] checking only csums items (without verifying data)
[6/7] checking root refs
[7/7] checking quota groups skipped (not enabled on this FS)
found 6970880000 bytes used, no error found
total csum bytes: 6340868
total tree bytes: 471728128
total fs tree bytes: 443301888
total extent tree bytes: 20905984
btree space waste bytes: 63863678
file data blocks allocated: 6499180544
referenced 14152331264
Here's a better formatted guide: https://xnux.eu/log/#010
I was able to get all OSs running on my Braveheart without any issues. Why was it that this wasn't recommended for the Braveheart?
I haven't tried expanding the partition yet; something I'll try later.
Thanks for the image - it was fantastic being able to try all OSs on one SD card without having to go through the hassle of flashing them all individually.
p-boot really works a treat!
(09-10-2020, 05:11 AM)SpoofyKid Wrote: I was able to get all OSs running on my Braveheart without any issues. Why was it that this wasn't recommended for the Braveheart?
This uses only 1.2 DTB, so the kernel will drive some HW incorrectly, notably type-c stuff, and modem powerup/powerdown will be probably broken.
I have to add support to p-boot to automatically load the correct DTB based on auto-detection of Pinephone variant, before this will properly support Braveheart.
Is it possible to flash this multi-image to the eMMC? I have version 1.1, so I can't really test it yet.
(09-10-2020, 06:51 AM)BillButter Wrote: Is it possible to flash this multi-image to the eMMC? I have version 1.1, so I can't really test it yet.
Yes. It should work as is when flashed to eMMC.
And now it's a 13 distro image. Smile
https://megous.com/dl/tmp/multi4.mp4
https://megous.com/dl/tmp/multi5.mp4
The image size is the same, despite the addition on 4 new postmarket OS variants. Smile
Very cool, megous. I'll have to try this one when I get a pinephone. Maybe the kernel support will look a little better then. If not, maybe I can help.
it doesn't get happy
it doesn't get sad
it just runs programs
P-boot is impressive! I´m looking forward to trying this on my braveheart!
"- is there already a tool for overclocking it desperately?"
  PinePhone - boot from microSD laserpyramid 8 686 Yesterday, 10:34 AM
Last Post: laserpyramid
  pinephone virtual keyboard aular 4 378 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 257 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 109,980 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,883 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 637 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,448 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 519 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,754 12-22-2023, 03:44 PM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 7,028 12-04-2023, 02:14 AM
Last Post: Peter Gamma
