"Fancy" screenshot tool not working
Below is a link listed from the Mobian wiki that should take screenshots once the "required packages are installed" my issue is it says notify-send isn't installed but when I use "sudo apt install bash libglib2.0-bin" as per the notify-send GitHub page, it says everything is installed. Has anyone tried this and had success? I'm at work right now or else I would dig a bit deeper.
https://puri.sm/posts/easy-librem-5-app-...creenshot/
Hi there, that woild have been me. Will check the instruction and make the list of dependencies more precise. It had worked on the pinephone when I tried it. Sorry, hut no time today....
(09-02-2020, 12:49 PM)spaetz Wrote: Hi there, that woild have been me. Will check the instruction and make the list of dependencies more precise. It had worked on the pinephone when I tried it. Sorry, hut no time today....
All is well, whenever you figure it out just feel free to let me know!
OK, tried it again and updated the instructions somewhat:
https://wiki.mobian-project.org/doku.php...screenshot
These are the dependencies:
sudo apt install libnotify-bin grim
and this is the screenshot script (I adapted it to store in /home/mobian rather /home/purism
#!/bin/bash
SCREENSHOT=${HOME}/Pictures/$(date +%Y-%m-%d-%H%M%S).png
notify-send -t 1000 screenshot "Taking a screenshot in 5 seconds"
sleep 5
grim "$SCREENSHOT"
notify-send screenshot "Screenshot stored at ${SCREENSHOT}
#!/bin/bash
sleep 5
grim "$SCREENSHOT"
Thank you, mate! I will fix the script today when I get home. I appreciate you getting back to me.
#!/bin/bash
sleep 5
grim "$SCREENSHOT"
Totally unrelated but I figure you know more about this then I do. Do you know where the information is stored when running the command to scale an app?
#!/bin/bash
sleep 5
grim "$SCREENSHOT"
Replied in your dedicated thread
#!/bin/bash
sleep 5
grim "$SCREENSHOT"
I think that this script is only not so useful for the main screen, since that one can only be seen if no apps are running.
In that case you can connect with SSH, and run grim from there.
Except unless you want to show off the background, it might have no meaning to make a screenshot of the main screen anyway.
  New camera app gnome-snapshot working on trixie? vusra 4 4,823 04-11-2025, 02:53 AM
Last Post: vusra
  Calls 4G not working oliwierzgorniak 2 5,451 08-06-2024, 02:20 PM
Last Post: baptx
  Mobile internet via cellular network mostly not working Anna 18 26,518 01-19-2024, 02:59 AM
Last Post: anonymous
Exclamation The internal speaker stops working anonymous 6 7,764 01-17-2024, 05:53 PM
  APN settings not working with new operator SIM card user641 1 3,865 03-01-2023, 04:43 PM
  Possible Solution for Microphone Not Working Ferriah 0 2,732 02-13-2023, 01:09 PM
Last Post: Ferriah
  Squeekboard stopped working Zebulon Walton 2 4,919 11-24-2022, 08:41 PM
  suspend inhibit no longer working jsch 3 5,826 10-23-2022, 09:20 AM
Last Post: LibrePhoneUser
  Rescue Your Mobian post Update Aug22 faster fix to working guide biketool 9 14,081 09-05-2022, 12:10 AM
  How to get Pinetime working with Pinephone arkadione 12 17,409 08-28-2022, 12:30 PM
Last Post: Fish
