Debian or Armbian 32 bit?
In the Wiki https://wiki.pine64.org/index.php?title=...Pro_images
there are couple of Debian / Armbian images listed.
Are any of these pure 32 bit ARM ?
thanks
Probably not. I believe the Armbian images are 64bit, and MrFixit's Debian is 64bit kernel with a 32bit userland. So if you need to run 32bit binaries, go with the MrFixit Debian.
the unofficial debian installer works great for 32bit, also, and uses an arm64 kernel.
MrFixiIts 32 bit userland appears to be good enough for what I need.
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 13,613 08-09-2025, 06:53 AM
Last Post: Sb2024
  Armbian fix, current version now works Sb2024 0 2,584 08-08-2025, 08:49 AM
Last Post: Sb2024
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 8 17,354 06-26-2025, 09:20 PM
Last Post: reukiodo
  Official Debian support moonwalkers 64 115,022 07-08-2024, 01:40 PM
Last Post: Humid Stylus
  Debian on Pinebook Pro u974615 7 11,496 03-31-2024, 10:11 AM
Last Post: u974615
  install debian on pbp jsch 7 11,459 11-22-2023, 04:22 PM
Last Post: TRS-80
  USB 3 port not working with Armbian zaius 3 5,635 11-13-2023, 01:54 PM
Last Post: zaius
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 21,790 09-07-2023, 09:38 PM
  Audio on Armbian Hobbes42 1 3,915 08-04-2023, 01:18 AM
  Blank screen after Armbian 20.04 install to emmc? psychoacoustic 3 9,156 04-01-2023, 03:22 PM
Last Post: TRS-80
