Dark screen on boot up (?) on new Pinebook Pro with Manjaro
Okay, I just have to laugh. I updated the packages on the SD card, rebooted it, and it came up with a dark screen. I can just re-image to the downgraded SD image for the card, and repeat the process, but an SD card image that can actually access the eMMC would be really nice right about now.
More importantly, thuis shows that this pitfall is still in the Manjaro package server, after other people have fallen for it. I am done with Manjaro at this point and will be looking for other OSes, and if they can't fix this, I think the Pinebook community should seriously consider moving to another distro
The Ubuntu Fosse SD image boots the laptop with a working display and lets me access the eMMC.
SO now I just need to know what to put into /etc/ to get the backlight turned on during boot up.
1. Just screen back-light not turning on?
2. Or LED over F2 key doesn't go GREEN from RED?
If case 2, you shold have done two "dd" commands for u-boot configuration after update (before reboot).
(08-18-2020, 04:35 AM)cynist Wrote: 1. Just screen back-light not turning on?
Just the screen backlight.
Boot ubuntu (SD) I assume it works?
edit/ make a file called "bright" (with sudo/su)
#/usr/bin/bash
cd /sys/class/backlight/edp-backlight
echo 3200 > brightness
(for some reason, space before and after ">" seems to be neccesary)
sudo chmod 777 bright
mount emmc (rootfs, not boot)
sudo cp bright to /mnt/emmc/root (replace emmc with appropriate)
shutdown, remove card
boot with emmc, ctr-alt-F2, do it twice (or more), wait until sure is booted
All this is blind, type carefully
login as root,,password ,, ./bright,, alt-F1 (preceding "./" is essential)
I have looked (grep) in /etc, trying to find where backlight values are stored, no luck
There is a systemd unit, seems dead or part of something else
  Debian on Pinebook Pro u974615 7 1,010 03-31-2024, 10:11 AM
Last Post: u974615
  Manjaro Sway Theme Broken Eighty8 1 280 03-08-2024, 08:41 AM
  Pinebook Pro upgrading from the factory image yamsoup 12 1,590 02-22-2024, 04:02 PM
  Attempting to install Void Linux, boots into a black screen 9a3eedi 0 340 02-18-2024, 08:54 AM
Last Post: 9a3eedi
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,756 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 328 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,143 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,220 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 88,803 12-08-2023, 11:25 PM
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 406 12-07-2023, 03:11 PM
