Please help...Pinebook Pro Night Color / mode not working :(
(08-12-2021, 01:32 PM)Dendrocalamus64 Wrote: So there are two bug reports that need to be filed.
1.  A regression broke Gnome Night Light on PBP
2. The dependencies in the package system are not adequate to get a working Wayland session.  Something wayland needs is not being pulled in when doing a minimal gnome install, but is present on the full image.
The question is whether to file these with Manjaro, Arch or Gnome.
Are #1 and #2 above Manjaro or Gnome related issue? Can anyone please advise?
Per my understanding, Manjaro is an official distribution for pinebook pro. Could I request a PBP moderator or developer escalate this issue?
thanks,
thanks,
Hi there. I'd start with Manjaro. You might find others with similar issues, and at worst you might be told to open additional bugs elsewhere.
Per escalations, I don't fancy any distribution for the PBP to be enterprise-class and therefore wouldn't have the same support expectations. Rather, it seems there are remarkable volunteers that invest an impressive amount of effort in making things work. I'd suggest making donations to projects to ensure both that developers get a few more resources and also to show thanks.
I see this same issue on my PineTab running Arch. Def following this thread!
(08-16-2021, 09:30 AM)tophneal Wrote: I see this same issue on my PineTab running Arch. Def following this thread!
Thanks, then it is an Arch issue not Manjaro.
As Manjaro is Arch based distribution. Would it then make sense to raise an issue with Arch Linux?
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 0 101 11-10-2024, 02:50 PM
Last Post: Sb2024
  Pinebook pro won't boot after bootloader installation jwensouls 4 932 08-21-2024, 04:17 AM
  Slackware Linux working on PBP vxzero 0 603 06-05-2024, 04:30 PM
Last Post: vxzero
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 401 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 2,862 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 4,106 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 3,215 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 3,506 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 103,459 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 2,693 11-23-2023, 07:37 AM
