PineTime suitable for wake-up alarms?
Hey all,
Playing with the thought to buy one, I wondered whether the PineTime is currently capable of waking you up via vibration -- presumably by notifying you about an alarm going off on your smartphone over a companion app, as this thread states an alarm app is to be developed.
Planning to use a PineTime with InfiniTime and Gadgetbridge as companion app, but did only find implicit statements for and against said capability.
Grateful for any answer Smile
Cheers
Currently, there's a couple of issues. Firstly, using GadgetBridge+Pinetime+Infinitime, the connection seems to drop quite frequently, requiring a restart of the PineTime before it can reconnect. Because of this, the chances of missing the alarm are high. Second, in my experience, when an alarm does go off, the Pinetime (with infinitime) only vibrates once, no matter how long the alarm is going off. A single vibration on your wrist with no sound, is not going to reliably wake many people up.
Hopefully later versions of Infinitime will work on both reliability of the bluetooth connection and also vibrating continually until dismissed (either on the watch or phone). When that happens it's likely to be a good option. Until then I'd suggest sticking with your phone near your bead. ;P
Yes, but only using Wasp OS currently. I use the pinetime to wake me every morning. The alarm in Wasp OS vibrates extremely energetically many times and has never failed to wake me.
Unfortunately battery life of Wasp OS is a lot shorter than that of infinitime, so the pinetime needs to be recharged every two days or so.
  Introducing RoutineHero: A PineTime Smartwatch for Kids' Routines + Companion App oscar-gardiazabal 3 3,675 06-06-2026, 03:33 PM
Last Post: oscar-gardiazabal
  Open-Source Support for PineTime LTE (eSIM) emilyjohnson63 2 4,284 11-01-2025, 05:55 PM
Last Post: euiccc2025
  Migrating to PineTime from a Fitbit dhdurgee 0 3,846 09-25-2025, 12:41 PM
Last Post: dhdurgee
  Brand new sealed Pinetime boot loop elver 0 10,817 09-10-2025, 06:41 AM
Last Post: elver
  Pinetime Black Screen philipallmon 1 5,640 07-30-2025, 11:44 PM
Last Post: karthick
  PineTime charging issues - connecting pins black gsoundsgood 2 3,763 09-15-2024, 02:59 PM
Last Post: gsoundsgood
  How do I clear all personal data from the pinetime smartwatch? taltamir 6 5,992 08-22-2024, 10:34 AM
Last Post: taltamir
  [SOLVED] Gadgetbridge not pairing with pinetime zoof 3 10,686 06-25-2024, 12:21 AM
Last Post: Amen
  PineTime at FOSDEM jmlich 5 6,617 02-07-2024, 11:48 PM
  PineTime turns off when removed from cradle tynstar 0 2,573 01-31-2024, 11:57 AM
Last Post: tynstar
