Replacement scissor switches (ANSI keyboard)?
Is it possible to purchase replacement "scissor switch" mechanisms for the PBP keyboard (ANSI layout, if it matters)? These are the two tiny pieces of white plastic under each keycap.  They're not actually a switch, they are what holds the key in place while allowing it to move up and down.  I foolishly decided to rearrange the keycaps on my PBP to match a nonstandard layout, and now I have two keys that want to fall off because I broke their scissors.   I don't see this in the replacement parts section of the storefront, short of buying an entire keyboard, which seems wasteful.
(07-19-2021, 07:45 AM)zackw Wrote: Is it possible to purchase replacement "scissor switch" mechanisms for the PBP keyboard (ANSI layout, if it matters)? These are the two tiny pieces of white plastic under each keycap.  They're not actually a switch, they are what holds the key in place while allowing it to move up and down.  I foolishly decided to rearrange the keycaps on my PBP to match a nonstandard layout, and now I have two keys that want to fall off because I broke their scissors.   I don't see this in the replacement parts section of the storefront, short of buying an entire keyboard, which seems wasteful.
Just PM me which keys and also ANSI or ISO, provide your shipping address and I will mail to you.
Thanks but I managed to scrounge the switches from elsewhere.
(08-07-2021, 01:32 PM)zackw Wrote: Thanks but I managed to scrounge the switches from elsewhere.
Noted :-)
  Replacement main board for Developers mozes 11 9,552 11-17-2024, 04:32 AM
Last Post: reukiodo
  Replacement touch pads Sb2024 0 1,661 11-14-2024, 10:05 PM
Last Post: Sb2024
  Bad replacement battery? chris88233 4 4,652 11-14-2024, 06:05 PM
Last Post: reukiodo
  Keyswitch scissors replacement cmj 1 2,298 10-14-2024, 05:35 PM
  Yet another new Pinebook keyboard problem MikoBob 3 3,737 09-11-2024, 07:05 AM
Last Post: MikoBob
  Replacement battery for PineBook Pro DrYak 3 5,286 11-07-2023, 10:09 AM
Last Post: DrYak
  Battery replacement mjc 2 5,405 09-26-2023, 01:08 AM
Last Post: david-lechner
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 201,682 09-13-2023, 03:43 AM
Last Post: k3dAR
  Separate ISO keyboard for PBP Besouro 0 2,274 06-04-2023, 02:51 PM
Last Post: Besouro
Information Keyboard Duplicate Keypress Fix RjraymondDuplicate 0 2,360 02-17-2022, 11:52 PM
Last Post: RjraymondDuplicate
