Axolotl on PinePhone / Mobian
#91
(06-02-2021, 12:36 AM)dante404 Wrote:
(05-28-2021, 07:52 AM)arno_nuehm Wrote: Axolotl is out in v1.0.0
Hi there,
I've updated from last version (already installed as .deb) to this new version (on up-to-date mobian), now Axolotl won't start anymore (nothing seems to happen when starting via icon).
I've already tried: Completely deinstall Axolotl, reboot, reinstall, start (fail), rebooted again, start (fail).
If I try to start Axolotl in terminal, these error message appears (after a strange "file is not a database" debug info):
ERRO[001] '/home/mobian/.config/textsecure.nanuc/electron/vendor/electron-linux-arm64/electron' exited with code: 1
then stopping worker und
[axolotl-electron] main: creating window failed: context canceled.
Any suggestions what I could try to fix this? Sad
Best Regards,
Dante
(BTW... THANKS FOR YOUR WORK ON THIS PROJECT ARNO!!! Smile )
You're very welcome!
Could you please try to rename the following folder by adding some digits at the end
and restart Axolotl via terminal. This will force Axolotl to re-install Electron and hopefully solve your problem. If Axolotl is working fine, you can delete the renamed folder completely.
Let me know, if this works for you.
Cheers!
Thank you Arno. Smile That didn' work (error message that a subdirectory of the renamed directory is missing).
But: I have deinstalled axolotl and manually searched and removed every folder or file somehow connected to/named like axolotl or textsecure, rebooted, reinstalled.. and it works again. Big Grin
One difference to the old version I've noticed:
I can no longer set a password (the password settings menu, and after trying to set one the whole app (until restart), is empty). Seems like a bug?
But afaik that has nothing todo with the messaging but only protecting the locally stored data, right? (On a encrypted mobian not really necessary I guess. Wink )
Again, thanks for your help! Smile
Best Regards,
dante
(06-03-2021, 03:57 AM)dante404 Wrote: Thank you Arno. Smile  That didn' work (error message that a subdirectory of the renamed directory is missing).
Best Regards,
dante
Glad to hear it worked somehow! But there must be a convenient way to re-install Electron and I can't remember how. But I'm on it.
Regarding the encryption password bug: Yes, I just tested it and it seems broken. I will open an issue on github to let the devs know. And yes, it just affects the local data.
Can you please share with a beginner how did you manually search and remove everything linked to axolotl?
Im also pressing the icon but nothing is starting even after waiting 10+ minutes. Ive tried purging axolotl and reinstalling but it leads to the same issue.
(06-11-2021, 07:16 AM)ergo owl Wrote: Can you please share with a beginner how did you manually search and remove everything linked to axolotl?
First I followed all remove variants described here , just for sure:
sudo apt remove --purge axolotl sudo rm /usr/share/applications/axolotl.desktop sudo rm -rf go sudo apt remove --purge npm nodejs mercurial golang python
Then I opened the file explorer Dolphin and used the search option to find all remaining files/directories with names containing "axolotl" and deleted them, then did the same step for "textsecure".
Then I rebooted and followed the install instructions:
git clone https://github.com/nuehm-arno/axolotl-mobian-package cd axolotl-mobian-package && sudo apt install ./axolotl_1.0.0-1_arm64.deb
SORRY for the late reply Sad , was on holiday...
Have you managed to work everything out or do you still need some help?
I was on holidays, too.
Hello there,
the latest update of libwpewebkit-1.0-3 from v2.30.6-1 to v2.32.1-1 makes Axolotl in daemonized setup unusable with the browser "cog" on my system.
Here you can find the old version, if you have the same problem and want to downgrade the library:
https://ftp.be.debian.org/debian/pool/main/w/wpewebkit/
Installation from the download folder via
sudo apt install ./libwpewebkit-1.0-3_2.30.6-1_arm64.deb
Hopefully, there will be another update soon.
And to prevent apt from updating the package again, use the following
sudo apt-mark hold libwpewebkit-1.0-3
("unhold" reverts this)
Cheers
v1.0.1-2 with fixes and improvements is out and you can find it here
Cheers!
Thanks! However I'm running into a problem - what's happening is after the first run which does take a little while, a nearly blank display pops up saying "404 page not found". (I did delete the textsecure.nanuc directories from a previous installation under .config and .local.) Looking at the terminal output it appears that before the 404 error axolotl was trying to popup a dialog box for entering a phone number but that never appears.
[mobian@mobian ~]$ axolotl INFO[0000] [axolotl] Starting Signal for Ubuntu version 1.0.1.1 INFO[0000] [axolotl] Setup completed                    INFO[0000] [axolotl] Start electron                    INFO[0000] [axolotl] Axolotl server started            INFO[0000] [axolotl] Starting axolotl ws                INFO[0000] astikit: starting worker...                  DEBU[0000] [axolotl] Using axolotl-web path ./axolotl-web/dist DEBU[0000] [axolotl] Run Backend                        DEBU[0000] [axolotl] openDb: /home/mobian/.local/share/textsecure.nanuc/db DEBU[0000] [axolotl] NewDataStore                      DEBU[0000] [axolotl] NewDataStore finished              ERRO[0000] [axolotl-electron] main: starting astilectron failed: provisioning failed: provisioning electron failed: unzipping /home/mobian/.config/textsecure.nanuc/electron/vendor/electron-linux-arm64-v12.0.0.zip into /home/mobian/.config/textsecure.nanuc/electron/vendor/electron-linux-arm64 failed: unzipping /home/mobian/.config/textsecure.nanuc/electron/vendor/electron-linux-arm64-v12.0.0.zip into /home/mobian/.config/textsecure.nanuc/electron/vendor/electron-linux-arm64 failed: astikit: opening overall zip reader on /home/mobian/.config/textsecure.nanuc/electron/vendor/electron-linux-arm64-v12.0.0.zip failed: zip: not a valid zip file INFO[0000] astikit: stopping worker...                  panic: runtime error: invalid memory address or nil pointer dereference [signal SIGSEGV: segmentation violation code=0x1 addr=0x0 pc=0x71e9e8] goroutine 37 [running]: github.com/asticode/go-astilectron.(*writer).write(0x0, 0xbd43fc, 0x11, 0xbe42d9, 0x1, 0x0, 0x0, 0x0, 0x0, 0x0, ...) /home/mobian/go/pkg/mod/github.com/asticode/go-astilectron@v0.22.3/writer.go:39 +0x1b8 github.com/asticode/go-astilectron.synchronousEvent.func1(0x40003ed240, 0xbddbf2) /home/mobian/go/pkg/mod/github.com/asticode/go-astilectron@v0.22.3/helper.go:145 +0x7c github.com/asticode/go-astilectron.synchronousFunc(0xd486e0, 0x40003ed280, 0xd39d80, 0x400038c500, 0x40002614f0, 0xbddbf2, 0x1c, 0x3, 0xbccf00, 0x40000ae260, ...) /home/mobian/go/pkg/mod/github.com/asticode/go-astilectron@v0.22.3/helper.go:133 +0x170 github.com/asticode/go-astilectron.synchronousEvent(0xd486e0, 0x40003ed280, 0xd39d80, 0x400038c500, 0x0, 0xbd43fc, 0x11, 0xbe42d9, 0x1, 0x0, ...) /home/mobian/go/pkg/mod/github.com/asticode/go-astilectron@v0.22.3/helper.go:144 +0xbc github.com/asticode/go-astilectron.(*Window).Create(0x400038c500, 0xbe42d9, 0x1) /home/mobian/go/pkg/mod/github.com/asticode/go-astilectron@v0.22.3/window.go:309 +0x158 main.runElectron() /home/mobian/go/src/github.com/nanu-c/axolotl/main.go:131 +0x550 main.runUI(0x0, 0x0) /home/mobian/go/src/github.com/nanu-c/axolotl/main.go:59 +0x8c created by main.main /home/mobian/go/src/github.com/nanu-c/axolotl/main.go:160 +0xe4 [mobian@mobian ~]$ axolotl INFO[0000] [axolotl] Starting Signal for Ubuntu version 1.0.1.1 INFO[0000] [axolotl] Setup completed                    DEBU[0000] [axolotl] Run Backend                        DEBU[0000] [axolotl] openDb: /home/mobian/.local/share/textsecure.nanuc/db INFO[0000] [axolotl] Axolotl server started            INFO[0000] [axolotl] Starting axolotl ws                DEBU[0000] [axolotl] NewDataStore                      DEBU[0000] [axolotl] Using axolotl-web path ./axolotl-web/dist INFO[0000] [axolotl] Start electron                    INFO[0000] astikit: starting worker...                  DEBU[0000] [axolotl] NewDataStore finished              INFO[0000] [axolotl] Loading Chats                      INFO[0000] [axolotl] Db setup finished                  ERRO[0000] [axolotl] InitModels open /home/mobian/.config/textsecure.nanuc/settings.yml: no such file or directory DEBU[0000] [axolotl] Start Session after Decryption    DEBU[0000] [axolotl] starting Signal connection        DEBU[0000] [axolotl] config path:  /home/mobian/.config/textsecure.nanuc DEBU[2021/07/20 11:57:50] [axolotl] Opening Dialog: getPhoneNumber    DEBU[2021/07/20 11:57:50] [axolotl-ws] send request getPhoneNumber    INFO[2021/07/20 12:04:14] [axolotl-electron] Electron App load
[Image: clyBzQP2_o.jpg]
(07-20-2021, 10:14 AM)Zebulon Walton Wrote: ...
I just
  1. backed up the textsecure directories
  2. did a git pull
  3. followed by a sudo apu install ./axolotl
and all seems fine.
There is no need (AFAIK) to delete the textsecure directories unless you want a fresh/unadulterated install.
  Mobian MMS/SMS text problem bcnaz 16 40,287 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 1,953 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 70,822 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 74,711 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 3,518 06-29-2025, 12:38 PM
Last Post: Hiraghm
  VoIP account on mobian dialer j_s 0 3,192 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 4,414 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 5,169 05-06-2025, 02:19 AM
  mobian calamares fail merom 2 4,853 04-29-2025, 02:10 PM
Last Post: mdk
  Pinephone seems tobe using 4G data instead of Wifi data grump_fiddle_reinstall 7 8,231 02-20-2025, 02:47 PM
Last Post: puffchumpy
