Another sudden Pinecil death
I received a pinecil from the latest batch today - sadly it only worked 2 times - once plugged into 20v via DC jack. The other time in a QC3 usb-c socket with a negotiated voltage of 15v.
During heating of a D24 TS-100 tip 8.Ohm@15V via usb-c the OLED screen froze and the buttons became unresponsive. After unplugging and reconnecting the pinecil the screen stayed off. The DFU mode also does not trigger. The pinecil does not show up as a USB device.
Further investigation resulted in the following: the pinecil when supplied with power via USB-c will consume about 120mA. A visual inspection of the pinecils board does not show any obvious damage or soldering faults.  The DC-DC converter (U8) on the board gets hot. The 3v3 regulator (U5) also gets hot. The 5v rail voltage is at ~4.0v. The 3.3v rail appears to be shorted to ground.
A cracked smd cap would explain this short very handily and this matches the accounts of a couple of other posts i saw in here. I already made a ticket in the pine64 system.
Did you get anywhere with support, they just pushed me along to IronOS Discussions on GitHub... I also noticed the bottom of my unit gets hot when plugged into USB (bottom area directly down from the OLED screen)
  Is Vector3d.shop a legitimate pinecil reseller? jamespo 0 222 12-03-2025, 07:40 AM
Last Post: jamespo
  Minimum temperature Pinecil pschalkwijk 1 669 10-16-2025, 10:40 PM
  Pinecil v2 not reaching 20v … Escape75 0 3,994 09-23-2025, 09:25 PM
Last Post: Escape75
  Pinecil v2 tip screw temperature Minuen 0 8,621 06-23-2025, 06:38 AM
Last Post: Minuen
  Crippling noise from inside pinecil during a few minutes high power soldering. dreieck 3 4,279 05-15-2025, 10:41 AM
Last Post: dreieck
  Pinecil v2 issue autumnharris 0 1,066 05-15-2025, 01:35 AM
Last Post: autumnharris
  Pinecil V2 doesn’t power on under any circumstances BigCarrotLeaf 0 1,598 03-22-2025, 07:29 AM
Last Post: BigCarrotLeaf
  Pinecil constantly cutting out WroughtIron 1 2,394 01-16-2025, 02:20 AM
Last Post: D4veC4rter
Exclamation Pinecil is working with 5v but nothing else!! MizterPink 1 1,676 01-07-2025, 03:59 PM
Last Post: MizterPink
  Pinepower suitable for an s23 (and a pinecil) its_lieseeeee 0 1,302 12-09-2024, 01:41 PM
Last Post: its_lieseeeee
