Automate checking whether the Pinecil is still in stock
Big Grin
Here is a quick way to see whether the Pinecil gets back in stock.
I've been meaning to get one, but it is out of stock. To automate my stalking of pine's website, i've written this python script and thought that I could share it if someone thinks that it's neat:
import requests as r
from tkinter import messagebox as m
import tkinter as tk
import os
url = "https://pine64.com/product/pinecil-smart-mini-portable-soldering-iron/?v=0446c16e2e66"
#don't show a main window
root = tk.Tk()
root.withdraw()
response = r.get(url)
source = response.text
startIndex = source.find("<title>")
endIndex = source.find("</title>")
if (startIndex == -1) or (endIndex == -1):
    m.showerror(title="could not check pine64.com", message="please check your internet connection")
    quit()
if("[Out of Stock]" in source[startIndex:endIndex]):
    print(source[startIndex:endIndex])
    m.showinfo(title="OUT OF STOCK", message="the Pinecil is stil out of stock, unfortunately")
else:
    choice = m.askquestion(title="IN STOCK", message="THE PINECIL IS BACK\nGo to the store?")
    if choice == 'yes':
        os.system("firefox "+url)
This will show the following when executed
https://ibb.co/XzLBd1P
https://ibb.co/XCcJb9D
the only thing left then is to add a menu item with the command:
python ~/checkPinecil.py
(replace "~/checkPinecil" with the path to your saved file)
Then you can easily check whether it is available Smile
P.s. I am aware of how useless this is, but I was bored and this is the result.
Best Regards, Julius
haha! this is awesome. i'd happily alter that and point people to it for the pbp, tab, and phone, too Big Grin
Hi. I'm not a python programmer. But I made a couple of small changes for Linux.
up the top put the following for direct execution. Assuming that's where you can find your python
#!/usr/bin/python3
and this down the bottom. replacing firefox with xdg-open to be a little more generic:
os.system("xdg-open "+url)
In my case it opens a tab in chromium because it's my default browser.
don't forget to chmod +x checkPinecil.py if you want to run the file directly.
e: Thanks again for posting. I just got the basics of your program running in MicroPython on an eap32. So I now have the basis of a standalone in-stock alert.
(02-01-2021, 08:45 PM)ImmortanJoe Wrote:
#!/usr/bin/python3
Those are good changes, I didn't really give machine independence a lot of thought when I wrote it.
I'm glad that this could serve as a basis, your project sounds really cool
Any rumor as to when the next will go on sale?
(01-27-2021, 02:15 PM)Julius_GU Wrote: Here is a quick way to see whether the Pinecil gets back in stock.
import os
root = tk.Tk()
root.withdraw()
    quit()
else:
    if choice == 'yes':
updated it so it also knows if something will be back soon also any browser will work now
import webbrowser as web
import os
root = tk.Tk()
root.withdraw()
    quit()
elif("[Schedule back in stock " in source[startIndex:endIndex]):
    m.showinfo(title="OUT OF STOCK", message="the Pinecil is scheduled to be back in stock")
else:
    if choice == 'yes':
        web.open(url, new=0, autoraise=True)
  Pinecil low temp mods? davidcoley 0 299 06-21-2026, 02:53 AM
Last Post: davidcoley
  my pinecil v2 is not working jagrav 0 747 04-17-2026, 06:28 AM
Last Post: jagrav
  Pinecil V2 doesn’t power on under any circumstances BigCarrotLeaf 1 2,663 03-28-2026, 02:37 AM
Last Post: Juptin
  Pinecil v2: Use car battery for power? FZB 0 747 03-02-2026, 09:56 AM
Last Post: FZB
  Is Vector3d.shop a legitimate pinecil reseller? jamespo 0 1,154 12-03-2025, 07:40 AM
Last Post: jamespo
  Minimum temperature Pinecil pschalkwijk 1 1,399 10-16-2025, 10:40 PM
  Pinecil v2 not reaching 20v … Escape75 0 4,527 09-23-2025, 09:25 PM
Last Post: Escape75
  Pinecil v2 tip screw temperature Minuen 0 9,324 06-23-2025, 06:38 AM
Last Post: Minuen
  Crippling noise from inside pinecil during a few minutes high power soldering. dreieck 3 5,583 05-15-2025, 10:41 AM
Last Post: dreieck
  Pinecil v2 issue autumnharris 0 1,601 05-15-2025, 01:35 AM
Last Post: autumnharris
