Pinebook Pro broken eDP connector
Hi all.
Last night, after disconnecting my PBP from an external display, I noticed that the display had started to look like this.  There's nothing open in this screenshot.[Image: -zil.jpg]
After a reboot it looked slightly better, more like this:
[Image: -ziI.jpg]
However, after reconnecting and disconnecting the external display it looked exactly like the first picture again.
Nothing changed after several reboots.
When I opened the laptop to try to reseat the display connector, I had some trouble getting it disconnected - to the point where I accidentally broke part of the socket:
[Image: -ziU.jpg]
Does anyone know where I can buy a replacement one (or more) of the piece I broke, or even if I can fix this issue at all without buying a new display / opening the display assembly?
Thanks in advance,
--Ocawesome101.
You should be able to buy the same connector separately and use only its "flap" portion to replace the one you broke.
(01-10-2021, 08:48 PM)dsimic Wrote: You should be able to buy the same connector separately and use only its "flap" portion to replace the one you broke.
Which connector would this be? Should I just look it up? Tongue
https://www.crystalfontz.com/product/cs0...cc-fpc-zif
Should be the correct type.
(01-11-2021, 07:52 PM)Ocawesome101 Wrote: Which connector would this be? Should I just look it up? Tongue
I really didn't know the exact part number, but you've already got the required information.  You may also consult the PineBook Pro schematic, which has some annotations for all of the connectors.
  Replacement battery for PineBook Pro DrYak 5 8,744 02-28-2026, 09:17 PM
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 5 9,723 01-02-2026, 04:26 AM
Last Post: stu73
  pinebook pro dixplays vertical stripes WEF 2 4,797 03-23-2025, 03:31 PM
Last Post: WEF
  Yet another new Pinebook keyboard problem MikoBob 3 5,424 09-11-2024, 07:05 AM
Last Post: MikoBob
  Lithium Battery Connector Franestra 0 3,144 04-02-2024, 01:52 AM
Last Post: Franestra
  Pinebook Pro on Debian 12 Power Issue u974615 1 4,659 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 4,702 02-17-2024, 07:06 PM
  Pinebook Pro charging issues tomekdev 1 3,723 01-05-2024, 08:40 PM
Last Post: tomekdev
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 232,069 09-13-2023, 03:43 AM
Last Post: k3dAR
  PineBook Pro dead ottahe 9 14,951 01-18-2023, 07:41 PM
Last Post: ottahe
