Chatty remotely
I would like to start Chatty remotely. I would like to handle text messages on a desktop computer.
Tried with ssh and X11Forwarding, but only starts Chatty on Pinephone, not on the computer.
Maybe via VNC? I just don't know if it's not too big a cannon Smile
You could try to find out how to force it to use the X11 backend instead of the default Wayland one. This varies, usually based on toolkit, assuming it's possible at all. For Geary it works with:
GDK_BACKEND=x11 geary
I expected this to work with Chatty too, but it didn't when I tried it. You might have to look at wayland forwardong options instead.
  Chatty Matrix Decryption Key jojuma 2 3,235 02-26-2024, 12:48 PM
  Jabber with chatty user641 2 3,698 11-12-2023, 02:10 AM
Last Post: user641
  Chatty does not work after suspend mode user641 4 6,388 07-18-2023, 10:43 AM
Last Post: alaraajavamma
  beware chatty 0.7.0~rc0-1 treebeard 6 7,418 11-06-2022, 04:51 PM
Last Post: treebeard
  Dist-upgrade and Chatty vs Gnome-Contacts biketool 9 10,964 09-30-2022, 08:53 PM
  Unable to send messages with chatty user641 0 2,127 09-07-2022, 04:35 AM
Last Post: user641
  Chatty - XMPP receiving photos - inline display doesn't work arkadione 2 4,669 07-10-2022, 03:16 AM
Last Post: arkadione
Sad Chatty can no longer start since the last update anonymous 10 12,652 06-08-2022, 01:03 PM
Last Post: Korac
  chatty v0.6 in Bookworm at last! treebeard 13 16,564 02-13-2022, 05:21 PM
  Chatty, SMS does not work - could hardware be at fault? AntonReiser 36 54,073 11-02-2021, 03:42 AM
Last Post: AntonReiser
