07-30-2020, 11:55 AM
you must check: Pinebook Pro structural integerity failing
Minor case damage with gentle use. (Is anyone else seeing this?)
10-26-2020, 10:19 PM
(07-30-2020, 11:55 AM)hdk Wrote: you must check: Pinebook Pro structural integerity failing This is the mentioned thread for reference: https://forum.pine64.org/showthread.php?tid=9658 My PBPro has some new issues that I'll likely be posting over there shortly. Just checked this thread to see if anyone else had the same trouble and it's clear I'm not the only one. ^_^ |
| Suggested software for use case | ehcorn | 4 | 6,935 |
08-17-2022, 04:06 PM Last Post: TRS-80 |
| Screws on bottom case coming loose | quadrantids | 8 | 14,096 |
01-20-2021, 03:47 AM Last Post: quadrantids |
| Pinebook Pro Case models | sundog | 2 | 5,624 |
11-05-2020, 09:31 AM Last Post: sundog |
| Got a case for my Pinebook Pro | GhostDragon | 3 | 7,452 |
09-24-2020, 07:24 PM Last Post: bastafari |
| Case defect (crack) | bigCamel | 25 | 45,900 |
08-18-2020, 03:41 PM Last Post: bigCamel |
| Case upgrade for my PBP | robt | 2 | 6,447 |
08-08-2020, 04:35 PM Last Post: Damon |
No case logo? No problem! | ALBNC1974 | 6 | 12,680 |
06-04-2020, 07:48 PM Last Post: Dendrocalamus64 |
