tor on pinebook pro
Hi, done a quick search but found nothing,
Installed the tor browser earlier and i get the error
"tor browser requires a cpu with SSE2 support, exiting"
Just wondered what the workaround is at the moment? if at all.
running manjaro at the moment like everyone else.
Any ideas would be good,
... where did you get your installed tor browser?
see:
https://sourceforge.net/projects/tor-browser-ports/
(05-29-2020, 05:13 PM)xmixahlx Wrote: ... where did you get your installed tor browser?
see:
Thanks for replying, I installed the normal tor browser first,
Second time i followed your link and installed the first download from that page.
and i get a different error.
"wrong architecture? 32-bit vs. 64-bit"
are all those links the same or do i need a specific one?
Thanks,
to answer my own question. i found a file called
https://sourceforge.net/projects/tor-bro....10-arm64/
tor-browser-linux-arm64-9.0.10_en-US.tar.xz.
*Tested on pine book pro works great
(05-30-2020, 02:59 AM)user8080 Wrote: to answer my own question. i found a file called
Just fyi for others who may have encountered similar issues: the problem is because the default file '**linux64** when directed to download from the TOR download page does not 'account' for A64 architecture - hence the no SSE support message. You just need to find the latest/current arm64 version and that should work on the PBP.
Summary:
1. if you are unable to run Tor from your pinebook pro, specifically encountering an error message that includes 'SSE'...
2. Go to https://sourceforge.net/projects/tor-bro...rts/files/
3. Look for a recent (if you wish) version with 'arm64', eg. '9.5.1-arm64'
4. choose a download that corresponds to your locale (language) eg. CN for chinese, EN for english etc
Hope this helps
Summary:
Hope this helps
So I downloaded this and it runs fine, but I have to dig to the .desktop file in the directory where I downloaded it and run that. Is there a way to properly "install" it, such that it shows up in the Application Launcher? I've searched around and I'm having trouble finding a procedure that fits this case. I'm on Manjaro Arm on the PBP. Any help pointing me in the right direction would be greatly appreciated. Thanks!
Summary:
Hope this helps
In terminal change to the directory with the desktop file and do
./start-tor-browser.desktop --register-app
(07-27-2020, 03:18 PM)futuretoast Wrote: In terminal change to the directory with the desktop file and do
That did it! Thank you!
  Window Maker Live for Pinebook Pro vajak 8 2,966 01-22-2026, 08:00 PM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 12,735 08-09-2025, 06:53 AM
Last Post: Sb2024
  Boot Order in Pinebook Pro food 11 12,686 03-28-2025, 10:08 AM
Last Post: DrYak
  Pinebook pro won't boot after bootloader installation jwensouls 4 6,535 08-21-2024, 04:17 AM
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 3,625 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 10,071 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 13,631 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 8,555 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 9,941 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 148,079 12-08-2023, 11:25 PM
