Android Rooted?
#31
(04-17-2016, 08:58 AM)tllim Wrote:
(04-16-2016, 02:01 AM)Tarjei85 Wrote: Nothing? not even an estimate?
Just for the record an answer like "We dont know, but we are working on it" would help. that way I would know you guys have looked in to it.
Targets on this week. Even myself also getting impatient able to slow Android build release and I have already given the ultimate to Android software team to release on this week.
Thank you for pushing this forward. Really looking forward to getting my hands on the rooted version.
As for the moment my Pine sits in its lego-casing gathering dust..  Angel
#32
And then the 0303 build of Android is available on the wiki. (Allready downloaded it and cant wait to get back from work and try if its rooted) Smile
#33
(04-21-2016, 09:38 AM)Tarjei85 Wrote: And then the 0303 build of Android is available on the wiki. (Allready downloaded it and cant wait to get back from work and try if its rooted) Smile
the 0303 is not a rooted version but the next version that we will tested today should be a rooted version. I will release the today 0422 version on next week when tested works well. The 0303 version is a first version compile with new BSP ver 1.20.
#34
Well thats a shame. I was hoping for root access on tbis release.
Guess I will have to wait yet another week.
#35
Has the Ethernet cable network connection in Android been fixed?  I tried 0303 and it wasn't.
#36
The 0303 already has the Ethernet cable network connected fix.
#37
I got a "partial" root on 0303.
Root only works via ADB, superuser or other apps can not find it yet..
Will try a few things tonight (+8h from now)
#38
I respectfully disagree.  I had mine connected to a 1Gig switch and even though I had an IP address Google play store was u-usable.
#39
(04-25-2016, 09:43 AM)gschanuel Wrote: I got a "partial" root on 0303.
If you find a good way to get root om 0303 you must tell us! =)
according to this thread: http://forum.pine64.org/showthread.php?tid=609
there is a way to root android, only problem is I dont have any machine running linux, so I'm not able to run the commands to get it working.
#40
After a few hours i was able to "brick" the current installation.
I messed to much on system files that now it boots on recovery.
Will try a bit more on the next days but I hope 0422 comes first!
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 506,501 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 39,905 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 23,757 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 9,892 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 10,798 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 8,169 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 5,128 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 334,693 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 5,730 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 135,318 02-10-2019, 07:44 PM
Last Post: mmmarcus
