My pinebook Pro does not turn on after installing Manjaro 20.02 kde
Dears, I have my pinebook pro since a few months ago and I had no problems with it. Yesterday I installed Manjaro 20.02 KDE and it worked fine, I installed some packages and then restarted. To my surprise, my Pinebook Pro did not turn on. The screen is black and you can't see anything. I tried to reinstall Manjaro and distro by default from my microsd, but it doesn't work. The screen when inserting the microsd is still black. The first light on the left side of the Pinebook Pro is green. The rest of the lights work when I lock the keyboard or touchpad.
What can I do?
I'm not sure if it's the same problem I encountered a while ago:
But for me the PBP was actually on and booted, just the display was very dark.
Try increasing the brightness with Fn+F2
You could also try to connect an external screen with an USB-C to HDMI converter to see what that does...
It's not a problem with the brightness, I tried pressing Fn+F2, but nothing happens.
I don't have a USB-C to HDMI. I bought one from China, but it will take a few months.
What else could I do?
(05-06-2020, 12:20 PM)iamnotapenguin Wrote: It's not a problem with the brightness, I tried pressing Fn+F2, but nothing happens.
Attention Fn + F2 to increase the brightness does not work on my PBP (kernel manjaro 5.6).
Try,  on the xorg terminal as a root user,
the command:
echo 3000> / sys / devices / platform / edp-backlight / backlight / brightness
This same command does not work from console (ctrl-alt-F2), it gives permission denied.
The problem is that the new brightness values now vary from 0 to 4095, a previous value set to 128 gives almost black screen.
It is advisable to prepare an image of the default system to be installed on an SD and use this system.
It happened to me the first time I used a 5.x kernel
In the dark I managed to change the brightness.
I’m having the same issue after running updates this afternoon. It’s not a screen issue as the system never boots. HDMI doesn’t produce any results and I can’t SSH in remotely. It’s acting like the machine is bricked. I’ll try booting from an SD card next.
the command:
How can I enter the terminal xorg? Thanks. When I boot from my microsd the screen is still black.
(05-06-2020, 06:54 PM)midnightcheese Wrote: I’m having the same issue after running updates this afternoon. It’s not a screen issue as the system never boots. HDMI doesn’t produce any results and I can’t SSH in remotely. It’s acting like the machine is bricked. I’ll try booting from an SD card next.
Tell us if you could fix it!
Thank you, everyone.
In my case I'm able to boot off the SD card. My plan is to reinstall Manjaro using the latest install image. I'm guessing since I had gone so long without updating the system (a month+ due to a mirror transition on the Manjaro end that I didn't discover until yesterday, I must have ended up with some type of Frankenstein system after reboot. There were upgrade conflicts and I'm sure my "solution" wasn't kosher.)
On the manjaro forum,, this is noted
Edit extlinux.conf,, change (4? places ) /something to ../something
Sorry, 3 places, kernel, fdt, initrd
I've tried everything and it still doesn't work. I can access into the terminal without problems, because when I type "poweroff" the computer turns off, but I have not been able to visualize the screen.
I also tried booting from a microsd with Debian, Manjaro, Chromium OS and it still doesn't work. I think that it boot because I can't disable the numeric keypad (the light doesn't turn on or off) and the screen turns on, but it doesn't show anything.
What could I do? Sad
  Pinebook pro bricked? michaelmoua 3 4,596 10-23-2025, 10:06 AM
Last Post: jceaser
Question Full desktop Surfing and Absolute Privacy on the pinebook? Www 2 6,639 08-10-2025, 10:35 PM
Last Post: Pattienner
  Pinebook problem meghancordo 1 3,998 07-24-2025, 07:28 AM
Last Post: mikehenson
Question Printing and scanning documents with pinebook? Www 0 3,561 06-28-2025, 01:25 AM
Last Post: Www
  Pinebook Pro in EU for Sale - €90 jan_vdk 4 6,867 06-19-2025, 02:14 AM
Last Post: shelfaberrant
  Use SD to install new OS over pinebook debian Rudy558 10 22,738 03-09-2025, 11:17 AM
Last Post: davisthomas
  Problem: Wi-Fi Connectivity Issues on Pinebook Pro markwood00 1 4,492 02-05-2025, 03:56 AM
Last Post: waylonwesley
  Pinebook Next !spekulation! Surehand53 2 5,279 01-23-2025, 11:49 AM
Last Post: Surehand53
  Pinebook Pro wants a PIN for my bluetooth mouse ColoBill 1 4,008 01-19-2025, 04:38 PM
Last Post: ColoBill
Tongue Yet another Pinebook Pro won't boot thread pinemouth 5 9,827 12-27-2024, 11:38 AM
Last Post: akash3995
