slarm64 (unofficial slackware) Rock64 RK3328 (aarch64)
#61
update:
- kernel 4.4.197
- update all packages Fri Oct 25 04:43:47 UTC 2019
slarm64-current-aarch64-base-rootfs-14Oct19-4.4.197-rock64-build-20191026.img.xz
slarm64-current-aarch64-base-rootfs-14Oct19-4.4.197-rock64-build-20191026.img.xz.md5
slarm64-current-aarch64-xfce-rootfs-14Oct19-4.4.197-rock64-build-20191026.img.xz
slarm64-current-aarch64-xfce-rootfs-14Oct19-4.4.197-rock64-build-20191026.img.xz.md5
kernel 5.4.0-rc5
kernel-firmware-rk3328-5.4.0-rc5-aarch64-1mara.txz
kernel-headers-rk3328-5.4.0-rc5-aarch64-1mara.txz
kernel-modules-rk3328-5.4.0-rc5-aarch64-1mara.txz
kernel-rk3328-5.4.0-rc5-aarch64-1mara.txz
updates:
download all files
run in console:
upgradepkg --install-new *rk3328-5.4.0-rc5*
update:
slarm64-current-aarch64-base-rootfs-20200118-4.4.211-rock64-build-20200127.img.xz
slarm64-current-aarch64-base-rootfs-20200118-4.4.211-rock64-build-20200127.img.xz.md5
slarm64-current-aarch64-xfce-rootfs-20200118-4.4.211-rock64-build-20200127.img.xz
slarm64-current-aarch64-xfce-rootfs-20200118-4.4.211-rock64-build-20200127.img.xz.md5
[url=http://dl.fail.pp.ua/slackware/images/rock64/slarm64-current-aarch64-xfce-rootfs-20200118-4.4.211-rock64-build-20200127.img.xz.md5][/url]
(01-28-2020, 12:36 PM)mara Wrote: update:
Did the default username:password changed? I failed to log in with neither root:'none' nor root:password.
Edit: I am accessing rock64 via ssh directly.
all is left
at the first boot and the second boot (automatically after the first), the root password is applied.
login: root
password: password
(04-07-2020, 11:51 AM)mara Wrote: all is left
login: root
password: password
Why I am still got access denied from ssh client? I have double checked the login credential, after watched the Rock64 reboot.
login: root
password: password
root login via password could be disabled for ssh. Can try from following options:
* Creating another account
* Using a key pair for root
* Editing /etc/ssh/sshd_config to enable root login via password
(04-07-2020, 11:34 PM)aaditya Wrote: root login via password could be disabled for ssh. Can try from following options:
What kind of hardware do I need to do that? I don't have any input/output device attached to the Rock64 for now.
Probably the same hardware you used to create your microsd in the first place. For example, insert the microsd in a laptop, mount it, then edit /etc/ssh/sshd_config adding the line:
PermitRootLogin yes
This should permit root login, but you should probably add a user account once you've ssh'd in, then delete PermitRootLogin from /etc/ssh/ssd_config. In the future you would ssh in with the user account and use su or sudo instead of logging in directly as root.  Safer that way.
All this is from arm.slackware.com, btw. A good resource.
after writing to sdcard, try to fix the configuration /<mount point sdcard>/etc/ssh/sshd_config and change the parameter
#PermitRootLogin prohibit-password
and
#PasswordAuthentication yes
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 14 20,921 Yesterday, 11:55 AM
  rAudio for Rock64 V2/Pine A64+ shinzuka 14 4,534 07-31-2026, 03:20 AM
Last Post: shinzuka
  DietPi OS for ROCK64 MichaIng 43 95,361 07-22-2026, 01:47 PM
Last Post: MichaIng
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 1,944 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 7,299 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 13,284 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 3,870 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 4,045 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 4,943 09-20-2024, 11:18 AM
Last Post: AwU2HBg
Smile First Lakka image for Rock64! Luke 47 116,826 09-01-2024, 06:05 AM
Last Post: RaymondDay
