04-02-2020, 09:43 AM
I see it says 5V output on the adapter for PBP, am I correct to assume that I could charge it through any standard USB outlet given that I have the correct round connector to go into the PBP?
| Charging problem | RicTor | 1 | 592 |
05-21-2026, 02:27 AM Last Post: Rodery |
P{inebook Pro not charging | Ome Ko | 6 | 6,329 |
11-09-2023, 03:29 PM Last Post: tomekdev |
| Pine Book Pro Charging Problems | balin | 7 | 12,883 |
12-15-2022, 02:15 PM Last Post: tomasgreenro |
| Very low battery (but charging) causes boot failures | Phillip Bell | 7 | 9,759 |
02-22-2022, 11:20 AM Last Post: wdt |
| Pinebook Pro Stopped Charging via USB-C | MickTheGeek | 4 | 8,066 |
08-25-2021, 02:51 PM Last Post: MickTheGeek |
| HArdware issues while charging | user18130814200115 | 2 | 5,110 |
05-01-2021, 04:13 AM Last Post: gabeeg |
| PineBookPro does not charging | floppy_rofling | 0 | 4,998 |
02-03-2021, 05:29 AM Last Post: floppy_rofling |
| Screen flicker with USB-C charging | bchenlee609 | 5 | 11,440 |
01-25-2021, 08:48 PM Last Post: bchenlee609 |
| USB-C Charging on the PBP? | Paulie420 | 33 | 57,603 |
12-12-2020, 02:20 PM Last Post: wrzomar |
| Charging via USB-C Port | tyha | 15 | 31,574 |
07-22-2020, 08:15 PM Last Post: iscmob |
