Games compilation howto on the Pinebook-pro (Manjaro Linux and Debian native)
#81
(03-28-2020, 02:42 AM)icecream95 Wrote:
(03-28-2020, 02:02 AM)Idaho Wrote: Talking about the panfrost driver can you tell us how to compile glxinfo? it's not here by default and it's not available in the repos, I have followed the howto you gave to install it but I'd like to check out if it's really installed or not Rolleyes
The source is at https://gitlab.freedesktop.org/mesa/demos, but most distributions do have packages with it.
On Arch-based distributions, it's in the mesa-demos package.
For Debian, try mesa-utils and mesa-utils-extra.
Oh thanks, I tried to install glxinfo on its own, I didn't think it'd be part of a larger package, AUR has it but it has no set of options to compile it for aarch64, hence why I thought I had to compile it myself, thanks for the clarification, it seems that my pbp is correctly running the panfrost driver, now time to set up pksrouce and get stuffs from astr0's repo I guess :3
Hi there, I've set up pksrc by following astr0's tutorial (here) but I'm stuck when it comes to setting up his custom repo, I'm getting the following error when I try to run:
[root@pbpro-manjaro pkgin]# /usr/pkg/bin/bmake install clean clean-depends
I get the following error:
ERROR: This package has set PKG_FAIL_REASON: ERROR: Please unset PKG_PATH before doing pkgsrc work! *** Error code 1 Stop. bmake: stopped in /usr/pkgsrc/pkgtools/pkgin
I don't understand why I should unset PKG_PATH, also, I'm unsure as to how to proceed  to do so Confused Any help would be welcome Smile
(03-31-2020, 12:20 PM)Idaho Wrote: Hi there, I've set up pksrc by following astr0's tutorial (here) but I'm stuck when it comes to setting up his custom repo, I'm getting the following error when I try to run:
Can you post whats in our ENV ?
$ env | grep PKG
I assume you correctly bootstrapped pkgsrc
Unset the PKG_PATH  like this
unset PKG_PATH   (I think you followed the article even in the examples of how to work normally with binary pkgsrc packages on NetBSD and not
directly with pkgin)
I have fixed the article as it might be a little misleading to people not entirely familiar with pkgsrc (sorry for that)
$ env | grep PKG
That's exactly what I did but I did it purposefully because I wanted to have both pkg_add and pkgin to be usable (even though I might not have gotten what's the difference between both).
Also that's weird, after a reboot, the PATH has been reset so there's nothing related to pgksrc in my ENV anymore even though it had been exported:
[root@pbpro-manjaro bin]# env | grep PKG [root@pbpro-manjaro bin]#
[root@pbpro-manjaro bin]# pkg_add bash: pkg_add: command not found
Also after setting up pkgin as it is in the tutorial, it fails to get the packages for some reason, returning that everything has an empty file size:
[root@pbpro-manjaro bin]# ./pkgin install alephone-20120514nb3 calculating dependencies...done. /usr/lib/libSDL_image-1.2.so.0, needed by SDL_image-1.2.12nb8 is not present in this system. /usr/lib/libSDL_sound-1.0.so.1, needed by SDL_sound-1.0.3nb6 is not present in this system. warning: package alephone-20120514nb3 has an empty FILE_SIZE on repository. warning: package SDL>=1.2.15nb17 has an empty FILE_SIZE on repository. warning: package SDL_image>=1.2.12nb6 has an empty FILE_SIZE on repository. warning: package SDL_net>=1.2.8nb1 has an empty FILE_SIZE on repository. warning: package SDL_sound>=1.0.3nb6 has an empty FILE_SIZE on repository. warning: package png>=1.6.0nb1 has an empty FILE_SIZE on repository. warning: package speexdsp>=1.2rc3 has an empty FILE_SIZE on repository. warning: package zziplib>=0.13.56 has an empty FILE_SIZE on repository. warning: package speex>=1.2rc2 has an empty FILE_SIZE on repository. warning: package flac>=1.1.3nb1 has an empty FILE_SIZE on repository. warning: package libmikmod>=3.2.0 has an empty FILE_SIZE on repository. warning: package libvorbis>=1.1.0nb1 has an empty FILE_SIZE on repository. warning: package physfs>=2.0.3nb1 has an empty FILE_SIZE on repository. warning: package smpeg>=0.4.4nb16 has an empty FILE_SIZE on repository. warning: package jpeg>=9 has an empty FILE_SIZE on repository. warning: package libwebp>=0.6.0 has an empty FILE_SIZE on repository. warning: package tiff>=4.0.3nb5 has an empty FILE_SIZE on repository. warning: package MesaLib>=7.11.2 has an empty FILE_SIZE on repository. warning: package glu>=7.11.2 has an empty FILE_SIZE on repository. warning: package libXext>=0.99.0 has an empty FILE_SIZE on repository. warning: package libXrandr>=1.1.2 has an empty FILE_SIZE on repository. warning: package libXt>=1.0.0 has an empty FILE_SIZE on repository. warning: package libICE>=0.99.1 has an empty FILE_SIZE on repository. warning: package libSM>=0.99.2 has an empty FILE_SIZE on repository. warning: package libX11>=1.1 has an empty FILE_SIZE on repository. warning: package libXrender>=0.9.2 has an empty FILE_SIZE on repository. warning: package libLLVM>=7.0.1nb2 has an empty FILE_SIZE on repository. warning: package libXdamage>=1.0.3 has an empty FILE_SIZE on repository. warning: package libXfixes>=4.0.1 has an empty FILE_SIZE on repository. warning: package libXxf86vm>=1.1.0 has an empty FILE_SIZE on repository. warning: package libdrm>=2.4.99 has an empty FILE_SIZE on repository. warning: package libelf>=0.8.5 has an empty FILE_SIZE on repository. warning: package libva>=2.3.0 has an empty FILE_SIZE on repository. warning: package libxcb>=1.6 has an empty FILE_SIZE on repository. warning: package libxshmfence>=1.2 has an empty FILE_SIZE on repository. warning: package wayland>=1.9.90 has an empty FILE_SIZE on repository. warning: package wayland-protocols>=1.17 has an empty FILE_SIZE on repository. warning: package jbigkit>=2.0 has an empty FILE_SIZE on repository. warning: package giflib>=5.2.1 has an empty FILE_SIZE on repository. warning: package readline>=6.0 has an empty FILE_SIZE on repository. warning: package libogg>=1.1.2nb1 has an empty FILE_SIZE on repository. warning: package libgetopt>=1.4.6 has an empty FILE_SIZE on repository. warning: package libffi>=3.0.11 has an empty FILE_SIZE on repository. warning: package libxslt>=1.1.28nb2 has an empty FILE_SIZE on repository. warning: package libXau>=1.0 has an empty FILE_SIZE on repository. warning: package libXdmcp>=0.99 has an empty FILE_SIZE on repository. warning: package libatomic_ops>=7.4.0<2000 has an empty FILE_SIZE on repository. warning: package libgcrypt>=1.6.0 has an empty FILE_SIZE on repository. warning: package libxml2>=2.8.0nb2 has an empty FILE_SIZE on repository. warning: package xmlcatmgr>=2.0beta1 has an empty FILE_SIZE on repository. warning: package libgpg-error>=1.13 has an empty FILE_SIZE on repository. Segmentation fault (core dumped)
How weird Huh
$ env | grep PKG
[root@pbpro-manjaro bin]# $env | grep PKG [root@pbpro-manjaro bin]#
How weird Huh
I will check on my pinebook looks like the files were not downloaded via pkgin .. strange I will let you know
But thanks for testing Smile
$ env | grep PKG
How weird Huh
OK I have fixed the corrupt pkg_info.gz index ..
Should be fine now
[root@pinebookpro packages]# /usr/pkg/bin/pkgin stats
Local package database:
    Installed packages: 540
    Disk space occupied: 5786M
Remote package database(s):
    Number of repositories: 1
    Packages available: 541
    Total size of packages: 0B
[root@pinebookpro packages]# /usr/pkg/bin/pkgin update
processing remote summary (http://45.76.81.249/pkgsrc/aarch64-linux/All)...
pkg_summary.gz                                                     100%  138KB  12.6KB/s   00:11
[root@pinebookpro packages]# /usr/pkg/bin/pkgin install xmahjongg
1 package to install:
  xmahjongg-3.70
0 to refresh, 0 to upgrade, 1 to install
433K to download, 565K to install
proceed ? [Y/n] Y
xmahjongg-3.70.tgz                                                 100%  433KB 432.9KB/s   00:00
installing xmahjongg-3.70...
pkg_install warnings: 1, errors: 0
pkg_install error log can be found in /var/db/pkgin/pkg_install-err.log
reading local summary...
processing local summary...
marking xmahjongg-3.70 as non auto-removable
Hey thanks for your answer astr0, I've trying this out and alephone (yeah I like the stuff) won't install with the following error:
[root@pbpro-manjaro /]# usr/pkg/bin/pkgin install alephone-20120514nb3 calculating dependencies...done. /usr/lib/libSDL_sound-1.0.so.1, needed by SDL_sound-1.0.3nb6 is not present in this system. 1 package to install:  alephone-20120514nb3 0 to refresh, 0 to upgrade, 1 to install 214K to download, 6158K to install the following packages have unmet requirements:   SDL_sound-1.0.3nb6 proceed ? [Y/n] Y installing alephone-20120514nb3... pkg_install warnings: 1, errors: 2 pkg_install error log can be found in /var/db/pkgin/pkg_install-err.log [root@pbpro-manjaro /]# tail /var/db/pkgin/pkg_install-err.log pkg_add: no pkg found for 'SDL_sound>=1.0.3nb6', sorry. pkg_add: Can't install dependency SDL_sound>=1.0.3nb6 pkg_add: 1 package addition failed ---Apr 01 19:18:51: removing xeyes-1.1.2... ---Apr 01 19:19:00: installing alephone-20120514nb3... pkg_add: Warning: package `alephone-20120514nb3' was built for a platform: pkg_add: Linux/aarch64 5.5.0 (pkg) vs. Linux/aarch64 5.6.0 (this host) pkg_add: no pkg found for 'SDL_sound>=1.0.3nb6', sorry. pkg_add: Can't install dependency SDL_sound>=1.0.3nb6 pkg_add: 1 package addition failed
Is there anything wrong on my end or is it on yours?
I tried simpler packages thoug and stuff like xeyes seem to work properly Wink
(04-01-2020, 11:23 AM)Idaho Wrote: Hey thanks for your answer astr0, I've trying this out and alephone (yeah I like the stuff) won't install with the following error:
SDL_Sound is present @ http://45.76.81.249/pkgsrc/aarch64-linux...0.3nb6.tgz
Im checking the alephone package now and will let you know, meanwhile can you just try pkgin SDL_sound and let me know if there are any  errors ?
Just reinstalled alephone on my Pinebookpro ->
root@pinebookpro user]# /usr/pkg/bin/pkgin install alephone
1 package to refresh:
  SDL_image-1.2.12nb8
2 packages to install:
  SDL_sound-1.0.3nb6 alephone-20120514nb3
1 to refresh, 0 to upgrade, 2 to install
2622K to download, 6158K to install
proceed ? [Y/n] Y
SDL_sound-1.0.3nb6.tgz                        100%  214KB 214.3KB/s   00:00
SDL_image-1.2.12nb8.tgz                       100%   71KB  71.0KB/s   00:00
alephone-20120514nb3.tgz                      100% 2337KB 467.4KB/s   00:05
refreshing SDL_image-1.2.12nb8...
installing SDL_sound-1.0.3nb6...
$NetBSD: MESSAGE,v 1.1 2012/02/12 14:17:10 wiz Exp $
Aleph One, the game engine, is installed. You will need data files in order
to play any games.
See games/marathon-trilogy or any other games/marathon-* package.
pkg_install warnings: 2, errors: 0
marking alephone-20120514nb3 as non auto-removable
[root@pinebookpro user]# uname -a
Linux pinebookpro 5.6.0-0.42-MANJARO-ARM #1 SMP Sat Mar 14 21:19:14 CET 2020 aarch64 GNU/Linux
[root@pinebookpro user]# date
Wed 01 Apr 2020 08:10:41 PM CEST
This is what I get when I try to install "SDL_sound-1.0.3nb6":
[idaho@pbpro-manjaro ~]$ sudo pkgin install SDL_sound-1.0.3nb6 calculating dependencies...done. /usr/lib/libSDL_sound-1.0.so.1, needed by SDL_sound-1.0.3nb6 is not present in this system. 0 to refresh, 0 to upgrade, 0 to install 214K to download, 538K to install the following packages have unmet requirements:   SDL_sound-1.0.3nb6 proceed ? [Y/n] Y [idaho@pbpro-manjaro ~]$
Nothing happens, then I just thought there'd be a bug in the script and that it might silently install but nope, alephone still doesn't install :/
Edit: On the bright side of things I installed quakespasm and it works like a charm Smile
(04-01-2020, 12:38 PM)Idaho Wrote: This is what I get when I try to install "SDL_sound-1.0.3nb6":
Hmm, I will check the SDL_sound package why it insists that /usr/lib/libSDL_sound-1.0..so.1 is present .. all pkgsrc should depend on libraries in /usr/pkg/lib
Thanks Idaho for checking !
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 17,214 Today, 04:48 AM
Last Post: deltaexploitss
  Updated Pinebook Pro? tantamount 2 2,638 06-20-2026, 10:14 AM
Last Post: tantamount
  Pinebook pro bricked? michaelmoua 4 8,416 05-26-2026, 02:20 AM
Last Post: Anthona
Thumbs Up Finally got Kali working on my Pinebook Pro! qingss0 0 1,969 04-04-2026, 08:00 AM
Last Post: qingss0
  dead Pinebook - help please RicTor 3 3,648 03-26-2026, 04:22 PM
Last Post: williamcorlin
  Pinebook problem meghancordo 2 7,110 03-18-2026, 08:58 AM
Last Post: RicTor
  Pinebook Pro in EU for Sale - €90 jan_vdk 5 11,051 02-09-2026, 12:50 AM
Last Post: Anthona
  Pinebook Pro for sale rfm83 0 2,174 11-08-2025, 09:22 AM
Last Post: rfm83
Question Full desktop Surfing and Absolute Privacy on the pinebook? Www 1 9,050 08-02-2025, 08:55 PM
Question Printing and scanning documents with pinebook? Www 0 5,401 06-28-2025, 01:25 AM
Last Post: Www
