PureOS on Pinephone
(03-21-2020, 02:50 AM)harvey186 Wrote: Can I also use apt upgrade / update to get the latest version ?
No, you will need to reflash.
I'm happy to announce a new version of PureOS for pinephone is available.
Features:
- new modemmanager (with frozen updates) compiled specifically for pinephone with updated udev rules
- calls/sms resume the phone from s2idle out of box due to device binary tree updates and an automatic AT command
- thanks to new udev rules, modemmanager now quick-detects the modem in time for calls to be answered from s2idle!
- phoshfix (press volup 3 times + voldown 3 times within 3 seconds) manually puts phone into s2idle
Known Issues:
- Resume from s2idle occasionally breaks phosh; the workaround is phoshfix + power key press to resume effectively.
- Modem quick detection only works for 1 or 2 calls from suspend. problem doesn't persist reboots, so workaround is to reboot your phone after finishing your phone call.
Thanks goes to mozzwald for his help with this.
https://droppy.ironrobin.net/#/Images/PureOS/2020-03-26
thanks, should this thread also be used for bugreports/problems?
because at the moment, i switched the terminal and i dont know how to get the normal one back
i wanted to visit youtube.com with the browser.
unfortunately, i mis-typed and tried to click the "back" icon in the german layout which just printed a "s", so i switched to terminal layout and was able to delete.
then i thought "hey what happens in terminal when i press this" and now i only see "F1..F12 Esc Tab Del PgUp" etc. and no way to get back to the normal terminal keyboard layout with a-z 0-9 etc.
(03-27-2020, 12:02 PM)someGermanGuy Wrote: then i thought "hey what happens in terminal when i press this" and now i only see "F1..F12 Esc Tab Del PgUp" etc. and no way to get back to the normal terminal keyboard layout with a-z 0-9 etc.
Press the "ABC" button (lower left corner) on the keyboard to return to regular letters
there was no "ABC" button on the keyboard
(03-27-2020, 01:25 PM)someGermanGuy Wrote: there was no "ABC" button on the keyboard
can you provide a pic please? i dont use german keyboard so it would help.
When using the terminal keyboard and you are on the Function key page it looks like the following image. The ABC button in the lower left returns you to the normal letter keyboard. If the ABC button was missing, something was wrong and you would need to provide more info or a photo of the issue might help.
.jpg   IMG_20200327_150249416_1.jpg (Size: 222.58 KB / Downloads: 879)
i cant reproduce it now but the buttons where much bigger, maybe some kind of scaling problem
when i am able to reproduce, i will make a picture
another question: is there any power saving available? the phone went pretty fast out of battery with wifi enabled
(03-28-2020, 08:39 AM)someGermanGuy Wrote: i cant reproduce it now but the buttons where much bigger, maybe some kind of scaling problem
Battery life depends on your use, screen on being the worst for battery life. After 5 minutes with screen off, the phone should enter s2idle sleep (not deep sleep) which helps with battery life.
the "use" was: the telephone was turned off, lie on the couch table.
i dont know what goes behind the scenes, but i had no application installed.
  Latest firmware for PinePhone modem! Subsentient 106 222,162 04-03-2026, 08:37 AM
Last Post: baptx
  Fedora + Phosh for PinePhone njha 77 212,480 01-14-2026, 12:22 AM
  Difficulty with openSUSE Tumbleweed Install PinePhone Beta danm1988 0 572 11-17-2025, 07:49 AM
Last Post: danm1988
  Movuan distribution for PinePhone merom 5 5,895 07-27-2025, 05:01 PM
Last Post: merom
  baremetal via Zig on PinePhone - JumpDrive help please WhiteHexagon 1 3,682 07-07-2025, 10:33 AM
Last Post: WhiteHexagon
  Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit] acid andy 40 62,013 12-28-2024, 12:19 AM
  Office applications for the Pinephone Peter Gamma 2 4,959 09-05-2024, 09:22 AM
Last Post: Peter Gamma
  Struggle to install LibreOffice on the PinePhone Peter Gamma 50 69,474 07-26-2024, 10:35 PM
  Why does Pine64 sabotage office on the Pinephone? Peter Gamma 5 6,593 07-04-2024, 07:34 AM
  Which word processor to choose for the Pinephone? Peter Gamma 16 18,282 06-22-2024, 07:28 AM
