Games compilation howto on the Pinebook-pro (Manjaro Linux and Debian native)
#71
How can I apply this patch?
Do you know if it will be merged upstream?
(02-26-2020, 09:14 AM)brzegorz Wrote: How can I apply this patch?
copy the patch file to the openmw root directory, delete the build directory (or whatever you called your build environment for cmake)
then run>   patch -p1 < name.of.the.patch
then compile as usual
mkdir build
cd build
cmake ..
build -j4
Hey guys, I see that GZDoom and AlephOne have been successfully compiled but there are no howtos for those, I tried following the instructions on the GZDoom wiki and I got stuck because it says I have no zmusic lib but I have found no way of installing it, also, found no instructions for AlephOne... What can I do??
(03-23-2020, 09:33 AM)Idaho Wrote: Hey guys, I see that GZDoom and AlephOne have been successfully compiled but there are no howtos for those, I tried following the instructions on the GZDoom wiki and I got stuck because it says I have no zmusic lib but I have found no way of installing it, also, found no instructions for AlephOne... What can I do??
Although modern GZDoom does work, performance isn't great, so you'll want to use an older version.
LZDoom is a fork of GZDoom which has the old OpenGL 2 renderer, which is much faster.
You can download the latest source from https://github.com/drfrag666/gzdoom/archive/3.85.tar.gz.
Compilation can be done through the standard CMake steps:
mkdir build
cd build
cmake ..
make -j6
sudo make install
LZDoom has the music system built in, so you won't need to install zmusic separately.
mkdir build
cd build
cmake ..
make -j6
sudo make install
Hey thanks for the advice, I compiled the games successfully and I can choose and run whichever .WAD I want but when I try to start the game it just crashes with the following app log:
./lzdoom
LZDoom <unknown version> -  - SDL version
Compiled on Mar 26 2020
LZDoom version <unknown version>
M_LoadDefaults: Load system defaults.
W_Init: Init WADfiles.
adding /usr/local/games/gzdoom-3.85/build/lzdoom.pk3, 710 lumps
adding /usr/local/games/gzdoom-3.85/build/game_support.pk3, 291 lumps
adding ./Doom.wad, 2306 lumps
I_Init: Setting up machine state.
V_Init: allocate screen.
S_Init: Setting up sound.
I_InitSound: Initializing OpenAL
 Opened device Built-in Audio Stereo
ST_Init: Init startup screen.
Checking cmd-line parameters...
S_InitData: Load sound definitions.
G_ParseMapInfo: Load map definitions.
Texman.Init: Init texture manager.
ParseTeamInfo: Load team definitions.
LoadActors: Load actor definitions.
script parsing took 781.48 ms
R_Init: Init Doom refresh subsystem.
DecalLibrary: Load decals.
M_Init: Init menus.
P_Init: Init Playloop state.
ParseSBarInfo: Loading custom status bar definition.
D_CheckNetGame: Checking network game status.
player 1 of 1 (1 nodes)
Using video driver x11
OpenGL acceleration requires at least OpenGL 3.0. No Acceleration will be used.
Resolution: 640 x 480
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.front
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround21
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround40
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround41
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround50
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround51
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround71
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.iec958
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
connect(2) call to /dev/shm/jack-1000/default/jack_0 failed (err=No such file or directory)
attempt to connect to server failed
ALSA lib pcm_oss.c:377:(_snd_pcm_oss_open) Unknown field port
ALSA lib pcm_usb_stream.c:486:(_snd_pcm_usb_stream_open) Invalid type for card
ALSA lib pcm_dmix.c:1089:(snd_pcm_dmix_open) unable to open slave
fluidsynth: error: SDL2 not initialized
** (process:37175): CRITICAL **: 13:58:47.542: Error setting locale
e1m1 - Hangar
** (process:37175): CRITICAL **: 13:59:08.962: Error setting locale
(process:37175): GLib-GObject-WARNING **: 13:59:08.963: cannot register existing type 'IpatchSplitsType'
(process:37175): GLib-GObject-CRITICAL **: 13:59:08.963: g_param_spec_enum: assertion 'G_TYPE_IS_ENUM (enum_type)' failed
** (process:37175): CRITICAL **: 13:59:08.963: ipatch_type_install_property: assertion 'G_IS_PARAM_SPEC(prop_spec)' failed
(process:37175): GLib-GObject-CRITICAL **: 13:59:08.963: g_boxed_type_register_static: assertion 'g_type_from_name (name) == 0' failed
(process:37175): GLib-GObject-WARNING **: 13:59:08.963: cannot register existing type 'IpatchSF2GenType'
(process:37175): GLib-GObject-WARNING **: 13:59:08.963: cannot retrieve class for invalid (unclassed) type '<invalid>'
** (process:37175): CRITICAL **: 13:59:08.963: file /build/libinstpatch/src/libinstpatch-1.1.3/libinstpatch/IpatchSF2Gen.c: line 148 (_ipatch_sf2_gen_init): assertion `enum_class != NULL' failed.
(process:37175): GLib-GObject-WARNING **: 13:59:08.963: cannot register existing type 'IpatchSample'
(process:37175): GLib-GObject-WARNING **: 13:59:08.963: cannot register existing type 'IpatchItem'
(process:37175): GLib-GObject-CRITICAL **: 13:59:08.963: g_type_interface_add_prerequisite: assertion 'G_TYPE_IS_INTERFACE (interface_type)' failed
(process:37175): GLib-GObject-WARNING **: 13:59:08.963: cannot register existing type 'IpatchSF2GenItem'
(process:37175): GLib-GObject-WARNING **: 13:59:08.964: cannot register existing type 'IpatchItem'
(process:37175): GLib-GObject-CRITICAL **: 13:59:08.964: g_type_interface_add_prerequisite: assertion 'G_TYPE_IS_INTERFACE (interface_type)' failed
(process:37175): GLib-GObject-WARNING **: 13:59:08.964: cannot register existing type 'IpatchSF2ModItem'
(process:37175): GLib-GObject-WARNING **: 13:59:08.964: cannot register existing type 'IpatchSF2VoiceCache'
(process:37175): GLib-GObject-WARNING **: 13:59:08.964: cannot retrieve class for invalid (unclassed) type '<invalid>'
(process:37175): GLib-GObject-CRITICAL **: 13:59:08.964: g_type_register_static: assertion 'parent_type > 0' failed
*** Fatal Error ***
Address not mapped to object (signal 11)
Address: 0xffff60515e50
!!! Could not create lzdoom-crash.log following signal
Segmentation fault (core dumped)
Did I do something wrong? Huh
Edit: The problem has been solved by tinkering with config files, looks like I'm getting used to the thing, even though it seems I still have a lot to learn at least I fixed one thing myself ^^
Edit2: Also I tried enabling the panfrost driver for better performances but I can't check if it's here or not because I can't install glxinfo, did I miss something?
(03-26-2020, 07:00 AM)Idaho Wrote: Hey thanks for the advice, I compiled the games successfully and I can choose and run whichever .WAD I want but when I try to start the game it just crashes with the following app log:
./lzdoom
M_Init: Init menus.
e1m1 - Hangar
*** Fatal Error ***
LZDoom defaults to the software renderer. To switch to the OpenGL renderer, you need to go into Options -> Change rendering output and enable hardware acceleration, then restart.
GZDoom compiled just fine on Manjaro aarch64 .. I had to build ZMusic too .. not a big deal .. and the game ran well with Panfrost drivers.
(03-27-2020, 04:35 PM)astr0baby Wrote: GZDoom compiled just fine on Manjaro aarch64 .. I had to build ZMusic too .. not a big deal .. and the game ran well with Panfrost drivers.
What version are you using?
Talking about the panfrost driver can you tell us how to compile glxinfo? it's not here by default and it's not available in the repos, I have followed the howto you gave to install it but I'd like to check out if it's really installed or not Rolleyes
(03-28-2020, 02:02 AM)Idaho Wrote: Talking about the panfrost driver can you tell us how to compile glxinfo? it's not here by default and it's not available in the repos, I have followed the howto you gave to install it but I'd like to check out if it's really installed or not Rolleyes
The source is at https://gitlab.freedesktop.org/mesa/demos, but most distributions do have packages with it.
On Arch-based distributions, it's in the mesa-demos package.
For Debian, try mesa-utils and mesa-utils-extra.
  Pinebook Pro for sale rfm83 0 500 11-08-2025, 09:22 AM
Last Post: rfm83
  Pinebook pro bricked? michaelmoua 3 5,009 10-23-2025, 10:06 AM
Last Post: jceaser
Question Full desktop Surfing and Absolute Privacy on the pinebook? Www 1 7,029 08-02-2025, 08:55 PM
  Pinebook problem meghancordo 1 4,329 07-24-2025, 07:28 AM
Last Post: mikehenson
Question Printing and scanning documents with pinebook? Www 0 3,827 06-28-2025, 01:25 AM
Last Post: Www
  Pinebook Pro in EU for Sale - €90 jan_vdk 4 7,278 06-19-2025, 02:14 AM
Last Post: shelfaberrant
  Use SD to install new OS over pinebook debian Rudy558 10 24,986 03-09-2025, 11:17 AM
Last Post: davisthomas
  Problem: Wi-Fi Connectivity Issues on Pinebook Pro markwood00 1 4,851 02-05-2025, 03:56 AM
Last Post: waylonwesley
  Pinebook Next !spekulation! Surehand53 2 5,865 01-23-2025, 11:49 AM
Last Post: Surehand53
  Pinebook Pro wants a PIN for my bluetooth mouse ColoBill 1 4,357 01-19-2025, 04:38 PM
Last Post: ColoBill
