(ARCHIVED) Debian Jessie Images (3.10.102 BSP Kernel) New Release
#91
Glad to hear it's going well! Thank you for all your hard work.
#92
(04-17-2016, 07:31 PM)lenny.raposo Wrote: the tar.gz are rootfs to be used with any kernel build you can come up with for th epine now the img.xz are teh fully images.
you must simply use something like 7zip to decompress teh file. Once decompressed you should have a full img to burn to sd card Wink
Thanks for the replay.
I found the following procedure, is it right?
umount /dev/sdb1
mkfs.ext3 /dev/sdb1
mount /dev/sdb1 /mnt/card
tar ‐xzvf filename.tar.gz ‐C /mnt/card
umount /dev/sdb1
I found the solution:
1) download the *.img.xz file
2) unzip with 7zip (or similar) and get the *.img file
3) mount with win32diskimager (or similar)
Thank again!
#93
thanks for all your hard and precious work lenny.raposo !
#94
Seconded, Many thanks for the work that you have done! I'm now a happy user of Debian on a Pine A64 -- Followed the instructions and now I have verified that indeeed, I have a real 64-bit system in front of me!
#95
Third, thanks Lenny.
#96
Lenny,
Thank you for this! I have a quick question that confuses me. How does your image compare to Longsleep's found here: https://www.stdin.xyz/downloads/people/l...es/ubuntu/
I am trying to determine the most stable image to use for my Pine+ which is in the mail. I already wrote Longsleep's to my SDCard and am wondering if I should replace it with yours.
Thank you.
#97
Both use the same 3.10.65 BSP kernel that longsleep compiled and maintains. The difference is that he is using Ubuntu 16.04 rootfs while I am devoted to the Debian 8 Jessie rootfs. I have also set up 3 different desktop environment images (Mate, XFCE, LXDE) and also the base without Desktop Environment Wink.
Both Longsleep's and mine udpate from longsleep's kernel build (includes the same scripts pine64_update_uboot.sh, pine64_update_kernel.sh, resize_rootfs.sh).
For those who want more bleeding edge go with Ubuntu and Debian is just rock solid in terms of stability but the apps will nto be the most recent versions Wink
If you like my work be sure to check out my site or wish to donate to the cause
Cheers Big Grin
#98
Thank you! Lots to think about.
Sent from my XT1254 using Tapatalk
#99
Hi Lenny,
What is the procedure to get the wifi working for the official wifi/bluetooth module? Thanks.
Bogdan
in terminal execute the following and let me know what you see
sudo -i
ifconfig
thanks
Cheers Big Grin
  Debian installer on Pine A64+ but no hdmi mrwick 1 8,462 07-28-2020, 01:49 PM
Last Post: kuleszdl
  Debian Pine64 h264/5 Video under vlc ozcy 6 19,205 04-15-2020, 05:27 AM
Last Post: dmitrymyadzelets
  OMV/debian/systemd: how to start the network kittyland 0 5,053 12-10-2019, 05:29 PM
Last Post: kittyland
  Debian 10 (Buster) in deep freeze - includes support for Pine64+ amp 5 15,742 07-22-2019, 09:29 PM
Last Post: amp
  Pine64 Debian Stretch/mainline [4.14.7] CallMeFoxie 50 159,524 07-22-2019, 09:24 PM
Last Post: amp
  Installing Debian with the Debian Installer (Buster RC1) amp 1 7,780 06-28-2019, 12:35 PM
Last Post: Kaarme42
  Script to build pure Debian images for Pine64+ amp 1 7,174 05-01-2019, 09:09 PM
  Debian (Stretch) for Pine64-LTS wgray 2 10,234 04-04-2019, 09:54 PM
Last Post: wgray
  Is there just one fuctioning Debian Desktop image? KNERD 7 19,770 03-29-2019, 02:00 AM
Last Post: desai_amogh
  how to set kernel parameter 'fsck.mode=force' marcelser 6 19,654 05-09-2018, 09:07 PM
Last Post: pfeerick
Users browsing this thread: 8 Guest(s)
