Games compilation howto on the Pinebook-pro (Manjaro Linux and Debian native)
#51
(01-11-2020, 01:41 AM)agD0i7rY Wrote: With the last sources of the eduke website I have a segmentation error. (I'd have to check if it's the stable or development version :p )
Running this then compiling again will fix it:
sed -i 's/ZPL_HAVE_RDTSC/UNDEFINED/' source/build/src/timer.cpp
The crash happens because eduke tries to read a CPU timer which is not normally available for userspace applications on ARM (it would have to be enabled by a kernel module first).
(01-25-2020, 06:14 PM)branon Wrote: Interesting. On aarch64 (pinebook) I get the same error about sodium
[branon@pbp bin]$ cmake -DBINARY_RELEASE=ON -DDEBUG=OFF ..
CMake Error at /usr/share/cmake-3.16/Modules/FindPackageHandleStandardArgs.cmake:146 (message):
 Could NOT find sodium (missing: sodium_LIBRARY_RELEASE
 sodium_LIBRARY_DEBUG) (found version "1.0.18")
Call Stack (most recent call first):
 /usr/share/cmake-3.16/Modules/FindPackageHandleStandardArgs.cmake:393 (_FPHSA_FAILURE_MESSAGE)
 CMake/Findsodium.cmake:224 (find_package_handle_standard_args)
 CMakeLists.txt:117 (find_package)
-- Configuring incomplete, errors occurred!
See also "/home/branon/git/devilutionX/bin/CMakeFiles/CMakeOutput.log".
See also "/home/branon/git/devilutionX/bin/CMakeFiles/CMakeError.log".
however on amd64 (void linux), this solves the issue for me and i am able to compile successfully:
[branon@netherworld bin]$ cmake -DBINARY_RELEASE=ON -DDEBUG=OFF ..
-- Found SDL2_mixer: /usr/lib/libSDL2_mixer.so
-- Configuring done
-- Generating done
-- Build files have been written to: /home/branon/git/devilutionx/bin
Edit: by commenting out the references to libsodium in https://github.com/diasurgical/devilutio...eLists.txt I was able to get the software to compile in aarch64
obtaining some game data now to see if it works
indeed it does. i can even create a multiplayer game and connect to myself on localhost
I guess I need to update my howto for Diablo2 Smile   When I compiled it I cannot recall I had to do this on Manjaro aarch64 ...
(01-19-2020, 06:05 AM)Luke Wrote:
(01-19-2020, 01:38 AM)icecream95 Wrote: [quote='Luke' pid='56937' dateline='1579189746']
I am encountering this issue with chocolate doom on default Debian.
If you prefer high resolutions and being able to look up and down, LZDoom is easy to compile and works with both Panfrost and the blob driver via gl4es.
https://github.com/drfrag666/gzdoom/archive/3.84.tar.gz
Compiling can be done through the standard CMake steps:
$ mkdir build
$ cd build
$ cmake .. -DCMAKE_BUILD_TYPE=Release
$ make -j`nproc`
$ sudo make install
For Panfrost, you'll want to use a very recent mesa-git as my bug fix for some levels such as E1M7 has only just been pushed.
I did get chcolate DOOM working Smile But I'll try this too.
Can you make some tutorial like the openarena you did Big Grin
Half Life (xash3d ) and Counter Strike (csmoe) I've tried to compile both but no luck at all I've always got some funny errors tutorials will be highly appreciated (stock debian)
(01-16-2020, 09:49 AM)Luke Wrote: I am encountering this issue with chocolate doom on default Debian.
$ mkdir build
$ cd build
$ make -j`nproc`
$ sudo make install
I will do it today
OpenArena on the Manjaro howto
https://astr0baby.wordpress.com/2020/01/...ng-part-2/
Thanks !
By the way, I had this message with ubuntu, I would have to try again with Manjaro.
I'm linking a thread with Doom Eternity Engine, which works: https://forum.pine64.org/showthread.php?tid=8997
I'm creating a separate one as it's easier to search for it and have game discussions grouped per game, IHO.
Do you guys know if there are any games like age of empires that can run on the pinebook pro?
(02-11-2020, 12:42 PM)hectorzg Wrote: Do you guys know if there are any games like age of empires that can run on the pinebook pro?
You can compile and run OpenAge https://openage.sft.mx/ , it is buildable on the Manjaro Linux
I couldn't run OpenAge but Julius runs well on the pbp. Are we listing on the first post the games that run on pbp?
Thumbs Up Finally got Kali working on my Pinebook Pro! qingss0 0 464 04-04-2026, 08:00 AM
Last Post: qingss0
  dead Pinebook - help please RicTor 3 1,173 03-26-2026, 04:22 PM
Last Post: williamcorlin
  Pinebook problem meghancordo 2 4,899 03-18-2026, 08:58 AM
Last Post: RicTor
  Pinebook Pro in EU for Sale - €90 jan_vdk 5 8,229 02-09-2026, 12:50 AM
Last Post: Anthona
  Pinebook Pro for sale rfm83 0 782 11-08-2025, 09:22 AM
Last Post: rfm83
  Pinebook pro bricked? michaelmoua 3 5,436 10-23-2025, 10:06 AM
Last Post: jceaser
Question Full desktop Surfing and Absolute Privacy on the pinebook? Www 1 7,365 08-02-2025, 08:55 PM
Question Printing and scanning documents with pinebook? Www 0 4,076 06-28-2025, 01:25 AM
Last Post: Www
  Use SD to install new OS over pinebook debian Rudy558 10 26,051 03-09-2025, 11:17 AM
Last Post: davisthomas
  Problem: Wi-Fi Connectivity Issues on Pinebook Pro markwood00 1 5,190 02-05-2025, 03:56 AM
Last Post: waylonwesley
