Pinebook Pro Screw Sizes???
Exclamation
Does anyone have definite screw sizes for the Pinebook Pro? I would really like them sooner rather then later because I have already lost two screws from the bottom of my PBP! (it is my fault because I didn't screw them back in all the way after reassembling it...) Would a kit like this: https://www.amazon.com/CO-RODE-Notebook-...crew+kit&a qid=1581169631&sr=8-8 have screws close to the ones in the PBP? Any help is appreciated!
Just broke out the Mitutoyo Calipers and took a couple screws out
All measurements in mm
Small screw:
Head - 3.44
Shaft - 1.97
Thread length - 2.1
Overall length - 3.05
Big screw:
Head - 3.44
Shaft - 1.97
Thread length - 4.41
Overall length - 5.85
Hope that helps.... I wouldn't think they'd need to be exactly that size but as close as possible
(02-08-2020, 08:35 AM)MIchael Wrote: Just broke out the Mitutoyo Calipers and took a couple screws out
Small screw:
Head - 3.44
Shaft - 1.97
Thread length - 2.1
Big screw:
Head - 3.44
Shaft - 1.97
Thanks sooo much for your prompt reply! Could you post a link to a reputable site (like Amazon) that sells these specific screws?
Small screw:
Head - 3.44
Shaft - 1.97
Thread length - 2.1
Big screw:
Head - 3.44
Shaft - 1.97
Better still perhaps if there are black (Japanned?) screw sets available - that would really look better (in my humble opinion) Smile
I'm not positive how they are measuring the screws on this one. but if they're doing overall length, 2x3 and 2x6 would work
https://www.amazon.com/QTEATAK-300Pcs-No...496&sr=8-1
How about these: M1 M1.2 M1.4 M1.7 Mix Carbon Steel PA Phillips Head Micro Screws Phillips Cross Pan Head Self-Tapping Electronic Small Micro Screws kit, 1000pcs https://www.amazon.com/dp/B07X1N69FM/ref...pEbNVN80XK ?
(02-08-2020, 09:32 AM)TDC_PBP Wrote: How about these: M1 M1.2 M1.4 M1.7 Mix Carbon Steel PA Phillips Head Micro Screws Phillips Cross Pan Head Self-Tapping Electronic Small Micro Screws kit, 1000pcs https://www.amazon.com/dp/B07X1N69FM/ref...pEbNVN80XK ?
I'm pretty sure those would be a disaster. Ya know, the whole coarse thread screw into a fine thread hole..... But if ya want to try.....
ebay link of some I think might work and they're black
https://www.ebay.ca/itm/MXCP1-450Pcs-M2-...0008.m2219
Small screw:
Head - 3.44
Shaft - 1.97
Thread length - 2.1
Big screw:
Head - 3.44
Shaft - 1.97
Thanks or measuring these! Have you had the opportunity to add them to the wiki?
Small screw:
Head - 3.44
Shaft - 1.97
Thread length - 2.1
Big screw:
Head - 3.44
Shaft - 1.97
 Hmmm....
   Wonder if the thread "pitch" would come into play ?
     or
   Perhaps at that small of size,  there may only be one pitch available...  ?
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
I haven't ever added anything to a wiki page but I can sure give it a try in a little bit.
As far as the pitch of the thread goes, it absolutely matters. If you try and put a course thread screw in a fine thread hole, you'll most likely break the plastic.
I broke out the tap and die set for the first time in 15 or so years and pulled out the gauge. When there are this small, it's hard for me to really tell. I'm going to guess from the blown up pic its a 0.6 but could also be a 0.5
.jpg   Screenshot_20200208-142611__01.jpg (Size: 267.52 KB / Downloads: 623)
  pinebook pro dixplays vertical stripes WEF 2 3,004 03-23-2025, 03:31 PM
Last Post: WEF
  Yet another new Pinebook keyboard problem MikoBob 3 3,559 09-11-2024, 07:05 AM
Last Post: MikoBob
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 4 6,697 05-06-2024, 09:27 AM
  Pinebook Pro on Debian 12 Power Issue u974615 1 3,234 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 3,166 02-17-2024, 07:06 PM
  Pinebook Pro charging issues tomekdev 1 2,771 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 5,075 11-07-2023, 10:09 AM
Last Post: DrYak
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 197,098 09-13-2023, 03:43 AM
Last Post: k3dAR
  PineBook Pro dead ottahe 9 12,451 01-18-2023, 07:41 PM
Last Post: ottahe
  Catastrophic failure of bottom screw mounts zackw 2 3,468 12-31-2022, 01:26 PM
Last Post: josmo
