Reaper on Pinebook Pro
(01-12-2020, 06:35 AM)mamboman777 Wrote: I use Focusrite gear and their website explains that they are still using USB 2.0 because it's fast enough and USB 3 for audio doesn't have much, if any, advantages.
That would depend on the bandwidth.  Anyway, it should be backwards compatible.
(01-07-2020, 08:43 PM)mamboman777 Wrote: Is the low latency kernel compatible or even advantageous with the PBP?
If you're talking about a just a PREEMPT 1000Hz kernel it will be fine and should give an improvement for low-latency tasks.
However, prepackaged distro kernels might not be compatible with the PBP, so you might have to spend a few hours compiling one yourself.
I've tried some of the alternative scheduler patches (MuQSS, BMQ), and it seems those are more designed for desktops with plenty of CPU power, so sticking with the default CFS is a good idea.
Has anyone tested Reaper + JACK2 MIDI yet? When I tried that last it was dropping lots of notes, though I probably just configured things wrong.
I installed Ardour, CALF Studio plugins, and Noise repellant on my Pinebook Pro running KDE Manjaro. I am very impressed with the Manjaro store. It set everything up and built all dependencies for me. I did a test session getting ready for a gig I have coming up. I was able to get the buffer set to 256 with 3 periods and avoid xruns. I am using a Scarlett 18i20 interface and aClarette Octopre connected via ADAT and BNC Wordclock.  I successfully wrote 18 tracks to disk for 1 hour without errors. That being said, I've found out that if I click "analyze exported audio" when I do an export I get crashes, but that's an Ardour question. Anywho, I'm super impressed and very pleased. It's such a sweet professional look to record onto this machine. With my nvme, I'll have plenty of room. I do feel like I want to get a cooling mat. Throttling could kill a recording session.
.jpg   1581216192914.jpg (Size: 194.44 KB / Downloads: 570)
  Updated Pinebook Pro? tantamount 2 1,601 06-20-2026, 10:14 AM
Last Post: tantamount
  Pinebook pro bricked? michaelmoua 4 7,186 05-26-2026, 02:20 AM
Last Post: Anthona
Thumbs Up Finally got Kali working on my Pinebook Pro! qingss0 0 1,345 04-04-2026, 08:00 AM
Last Post: qingss0
  dead Pinebook - help please RicTor 3 2,580 03-26-2026, 04:22 PM
Last Post: williamcorlin
  Pinebook problem meghancordo 2 6,046 03-18-2026, 08:58 AM
Last Post: RicTor
  Pinebook Pro in EU for Sale - €90 jan_vdk 5 9,721 02-09-2026, 12:50 AM
Last Post: Anthona
  Pinebook Pro for sale rfm83 0 1,537 11-08-2025, 09:22 AM
Last Post: rfm83
Question Full desktop Surfing and Absolute Privacy on the pinebook? Www 1 8,272 08-02-2025, 08:55 PM
Question Printing and scanning documents with pinebook? Www 0 4,796 06-28-2025, 01:25 AM
Last Post: Www
  Use SD to install new OS over pinebook debian Rudy558 10 28,462 03-09-2025, 11:17 AM
Last Post: davisthomas
