Pinebook Pro Fingerprint Magnet
#21
(11-30-2019, 01:05 AM)clover Wrote: I think its a great idea to have dbrand-esque skins for this as wells as the PinePhone! Smile
That's the goal! Big Grin  If there are any patterns/designs you see that might look good as one, let us know, and we'll see if we can adapt it. We're very close to having templates done. Once we do, I'm going to start prototyping the simpler design MrTester suggested.
#22
Can't wait to see.
Perhaps if you have some that are really liked in the community we could work out some sort of promotion.
#23
I would be down with that. I've already thought of offering any that are popular and simple enough to produce over to Pine64, to do with as you please, or to make them publicly available as ready to print/cut with advisories concerning printing and application.
#24
Honestly just a matte color (maybe the pine64blue and black) would be great. I also like the dragon skin from DBrand but it might be harder to recreate that texture.
#25
If you can, send me links to any generic designs you'd like to see adapted, or something similar produced. If the dragon skin is a scale pattern, that wouldn't be too hard to create. I'd just have to focus on one tiny portion to define it as the pattern fill.
#26
https://forums.macrumors.com/threads/dbr...19&slide=0
This link should take you to examples of the dragon skin.
#27
(12-02-2019, 05:08 PM)clover Wrote: https://forums.macrumors.com/threads/dbr...19&slide=0
Thanks!
Looking at it now, we could emulate the visual texture, but it would likely be very costly to produce skins with the actual physical texture. I'll add it to the list to look into, though!
Looked into it, it'd be easy for a phone, probably a nightmare with anything bigger than the Tab.
#28
Yea, a vinyl can be quite expensive ... unless its carbon, those are usually quite cheap.
#29
I'm thinking I can just mask off and spray PlastiDip. :-)
— Jeremiah Cornelius
  Updated Pinebook Pro? tantamount 2 2,148 06-20-2026, 10:14 AM
Last Post: tantamount
  Pinebook pro bricked? michaelmoua 4 7,835 05-26-2026, 02:20 AM
Last Post: Anthona
Thumbs Up Finally got Kali working on my Pinebook Pro! qingss0 0 1,685 04-04-2026, 08:00 AM
Last Post: qingss0
  dead Pinebook - help please RicTor 3 3,143 03-26-2026, 04:22 PM
Last Post: williamcorlin
  Pinebook problem meghancordo 2 6,536 03-18-2026, 08:58 AM
Last Post: RicTor
  Pinebook Pro in EU for Sale - €90 jan_vdk 5 10,432 02-09-2026, 12:50 AM
Last Post: Anthona
  Pinebook Pro for sale rfm83 0 1,855 11-08-2025, 09:22 AM
Last Post: rfm83
Question Full desktop Surfing and Absolute Privacy on the pinebook? Www 1 8,697 08-02-2025, 08:55 PM
Question Printing and scanning documents with pinebook? Www 0 5,109 06-28-2025, 01:25 AM
Last Post: Www
  Use SD to install new OS over pinebook debian Rudy558 10 29,525 03-09-2025, 11:17 AM
Last Post: davisthomas
