11-03-2019, 02:06 PM
Debian Desktop off SD?
11-03-2019, 05:40 PM
I edited the extlinux.conf on the boot partition of the microsd and changed "root=PARTUUID=deedbeef-02" to the device holding the root partition on the microsd "root=/dev/mmcblk0p2". After that it booted.
Matthew
11-03-2019, 10:36 PM
(11-03-2019, 12:43 PM)zaius Wrote: I just used the Pine64 installer to flash the SD. Yes, this has been confirmed in this thread: https://forum.pine64.org/showthread.php?...1#pid51491 I intend test this out tomorrow.
11-05-2019, 01:36 PM
(11-03-2019, 10:36 PM)hmuller Wrote:(11-03-2019, 12:43 PM)zaius Wrote: I just used the Pine64 installer to flash the SD. This worked for me but what steps can I take to re-image my machine so I don't need to boot from the SD all the time?
11-05-2019, 01:55 PM
(11-05-2019, 01:36 PM)xircledev Wrote:(11-03-2019, 10:36 PM)hmuller Wrote:(11-03-2019, 12:43 PM)zaius Wrote: I just used the Pine64 installer to flash the SD. I put a copy of the image on a usb flash drive, booted the SD and then dd'd the image from the usb drive to the eMMC . But just to be safe, after the dd finished, I mounted the boot partition on the eMMC and edited the extlinux.conf there to replace "root=PARTUUID=deedbeef-02" with the device holding the root partition on the eMMC "root=/dev/mmcblk1p2". Matthew
11-05-2019, 02:11 PM
(11-05-2019, 01:36 PM)xircledev Wrote:I messed up my default Debian distribution (don't try to update to Sid) and had the same problem described above running the image on SD, but when I wrote the image directly to MMC using dd it worked.(11-03-2019, 10:36 PM)hmuller Wrote:(11-03-2019, 12:43 PM)zaius Wrote: I just used the Pine64 installer to flash the SD. (11-03-2019, 01:24 PM)m80 Wrote: I've also tried the pinebookpro-debian-desktop-mrfixit-190905.img multiple times on 3 different microsd cards with the same results as you... I see the boot splash, briefly see the console login, and then I get a blank screen. I have the same problem. I can't seem to boot. I've tried two SD cards now. After imaging the card with `dd`, inserting it into the PBP and hitting the power button, I get the "Open Sesame" splash screen. Then it black screens and hangs. If I try and boot it a second time from the same card the PBP just black screens. Ben
11-05-2019, 02:59 PM
(11-05-2019, 02:23 PM)Feakster Wrote:(11-03-2019, 01:24 PM)m80 Wrote: I've also tried the pinebookpro-debian-desktop-mrfixit-190905.img multiple times on 3 different microsd cards with the same results as you... I see the boot splash, briefly see the console login, and then I get a blank screen. This is how I got past it: https://forum.pine64.org/showthread.php?...2#pid51492 (11-05-2019, 02:59 PM)m80 Wrote:(11-05-2019, 02:23 PM)Feakster Wrote:(11-03-2019, 01:24 PM)m80 Wrote: I've also tried the pinebookpro-debian-desktop-mrfixit-190905.img multiple times on 3 different microsd cards with the same results as you... I see the boot splash, briefly see the console login, and then I get a blank screen. Hi, Thanks for your help. It worked, the wrong partuuid was specified in the config file. Sorted it now. Kind regards, Ben (11-05-2019, 01:55 PM)m80 Wrote:(11-05-2019, 01:36 PM)xircledev Wrote:(11-03-2019, 10:36 PM)hmuller Wrote:(11-03-2019, 12:43 PM)zaius Wrote: I just used the Pine64 installer to flash the SD. Sorry if this is a stupid question, but how exactly do you mount the boot partition on the emmc and edit it from there? Sorry I'm a noob and just want to be able to get back to default if I mess up. I flashed the image to the emmc but it won't boot without the SD card in now. I think it's because that extlinux. Conf file isn't edited right after I flashed it. I could use the gui to edit the boot in the SD, but can't use the gui to edit the emmc. How does one do this? Edit: I figured it out with mount and nano. Thanks. |
