keyboard problem
Just got new Pinebook Pro and after first testing I realized the laptop keyboard is so bad I cannot write on it. I have to press key couple of times to type 1 single character. It is impossible to use such keyboard. It seems to be HW issue as when I attached external keyboard it worked fine.
How can this be fixed?
(11-04-2019, 03:43 AM)romansvec Wrote: Just got new Pinebook Pro and after first testing I realized the laptop keyboard is so bad I cannot write on it. I have to press key couple of times to type 1 single character. It is impossible to use such keyboard. It seems to be HW issue as when I attached external keyboard it worked fine.
Must be specific to your unit. On my unit the keyboard works just fine. Did you check if any key is stuck? IF not it might be a classical warranty case.
nothing stuck it happens for most of the keys, so hopefully warranty case
Confirmed issue. I had problems when trying to set my new password on initial login of the default Debian. My girlfriend noticed and pointed it out too, when one Chromium. Happens very sporadically, and not to any particular key, either. Seems to occur when typing past a certain speed.
If you are having issues with the keyboard registering presses, and you're sure it's not just an unfamiliar keyboard, email pinebook@pine64.org about it.
Not specific to his/her unit unfortunately; I just got my Pinebook Pro today and have exactly the same problem.
I thought i had a similar problem... turned out i was somehow touching the touchpad while typing. Using Fn+F7 to disable the touchpad (or enable it) cleared it up 100%, so i'm conviced it was not mechanical or system related in my case. I'd much rather us a wireless mouse in any case.
I hope it's an easy fix for you(s). Given how much we were all looking forward to getting our new PBP's, it's easy to imagine the frustration.
(11-04-2019, 09:00 PM)Watercourse Wrote: I thought i had a similar problem... turned out i was somehow touching the touchpad while typing. Using Fn+F7 to disable the touchpad (or enable it) cleared it up 100%, so i'm conviced it was not mechanical or system related in my case. I'd much rather us a wireless mouse in any case.
Thank you Watercourse - that's what was causing it! I also stumbled upon the explanation at General Discussion on Pinebook Pro > "Key Presses Not Registering":
"The issue occurs when your thumb or edge of the palm makes contact with left or right tip of the trackpad when you type. Basically its a case of palm rejection firmware being stupid - instead of disabling the trackpad (so your cursor doesn't dance all over the place) it actually disables both the trackpad and the keyboard."
Thank you all for the clear description of the problem, and work around.
I've added an entry for this last issue to the Trouble Shooting Guide;
Wiki - Pinebook Pro - Keys not registering
As usual, feel free to correct, improve or comment, (good or politely bad).
Arwen Evenstar
Princess of Rivendale
I've been experiencing the same problem. The Fn-F7 fix works well for uses involving extended typing but is very inconvenient in other situations, where it's necessary to switch frequently between typing and clicking (e.g., certain online forms and some password entry screens). I would rather not attach a mouse if I can avoid doing so -- I sometimes work on cramped surfaces.
Can anyone say what the prospects are of improved palm rejection in the near future?
  Yet another new Pinebook keyboard problem MikoBob 3 3,898 09-11-2024, 07:05 AM
Last Post: MikoBob
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 205,460 09-13-2023, 03:43 AM
Last Post: k3dAR
  Problem with USB 3.0 Type A hobbitus 4 4,610 07-15-2023, 11:14 AM
Last Post: dachalife
  Separate ISO keyboard for PBP Besouro 0 2,323 06-04-2023, 02:51 PM
Last Post: Besouro
Information Keyboard Duplicate Keypress Fix RjraymondDuplicate 0 2,428 02-17-2022, 11:52 PM
Last Post: RjraymondDuplicate
  keyboard and usb ports not working User 24565 3 5,707 02-15-2022, 10:12 AM
  Replacing the Keyboard gabb 6 11,050 01-11-2022, 07:39 AM
Last Post: Valenoern
  power on PBP if your keyboard is dead? stozi 0 2,824 11-29-2021, 01:55 PM
Last Post: stozi
  Replacement scissor switches (ANSI keyboard)? zackw 3 7,022 08-09-2021, 09:20 PM
  Some keyboard keys not working oddsocks 10 17,882 04-20-2021, 08:33 AM
Last Post: dsimic
