Pinebook Pro won't turn on
Received my PBP today and I have the same problem to boot up. I removed the back panel and pressed the reset button but still not working. Does anyone have a solution?
(11-01-2019, 11:12 PM)hsm89cheu Wrote: Received my PBP today and I have the same problem to boot up. I removed the back panel and pressed the reset button but still not working. Does anyone have a solution?
Some people have had success with reseating the emmc card, then pressing reset.  Unfortunately, I am not among them.
I flipped the eMMC switch (24 on https://wiki.pine64.org/index.php/Pinebook_Pro_Main_Page#Accessing_the_Internals_-_Disassembly_and_Reassembly)
and my computer now boots.
Which direction is the switch supposed to be ?
EDIT: Success! I flipped the emmc switch to up (towards the hinge) pressed reset, and then power, the system powered on finally!
@codebreaker if you feel that the issue has been solved, please mark thread as solved.
@TAAPAye & @bebop_man, thank you for the information.
I've added a section to the Wiki for trouble shooting our PBPs. Then added that specific issue;
Wiki - Pinebook Pro - New from the factory - won't boot or power on
As usual, feel free to correct, improve or comment, (good or politely bad).
Arwen Evenstar
Princess of Rivendale
I am having a similar problem except I received my PBP yesterday and it wouldn't power up and I set it down walked away about 10 minutes later my wife said it turned on. I played with it all night, rebooted it several times, then finally powered off and went to bed. now today it won't turn on at all. followed all previous instructions(the emmc switch was set correctly, and emmc very secure) I hope it didn't expire in the middle of the night I was so happy with everything.
The instructions from TAAPAye and bebop_man worked for my PBP finally. Thanks.
#19
Sorry tp hear that. Hopefully someone more familiar with the hardware will be able to chime in to help you.
#20
(11-03-2019, 09:18 PM)Baius Wrote: I am having a similar problem except I received my PBP yesterday and it wouldn't power up and I set it down walked away about 10 minutes later my wife said it turned on. I played with it all night, rebooted it several times, then finally powered off and went to bed. now today it won't turn on at all. followed all previous instructions(the emmc switch was set correctly, and emmc very secure) I hope it didn't expire in the middle of the night I was so happy with everything.
  pinebook pro dixplays vertical stripes WEF 2 2,980 03-23-2025, 03:31 PM
Last Post: WEF
  Yet another new Pinebook keyboard problem MikoBob 3 3,535 09-11-2024, 07:05 AM
Last Post: MikoBob
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 4 6,649 05-06-2024, 09:27 AM
  Pinebook Pro on Debian 12 Power Issue u974615 1 3,208 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 3,134 02-17-2024, 07:06 PM
  Pinebook Pro charging issues tomekdev 1 2,753 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 5,033 11-07-2023, 10:09 AM
Last Post: DrYak
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 196,443 09-13-2023, 03:43 AM
Last Post: k3dAR
  PineBook Pro dead ottahe 9 12,437 01-18-2023, 07:41 PM
Last Post: ottahe
  Pinebook Pro malfunctioned hardware samtux 10 10,799 12-27-2022, 03:31 PM
Last Post: samtux
