Pinebook Pro?
(07-26-2019, 10:08 PM)wizkies Wrote: I wonder where can i get the coupon
The coupon will be sent to you via e-mail after you enter your forum credentials on the preorder page. Only forum accounts that were created before 1st July are eligible.
(07-26-2019, 11:51 PM)hdk Wrote: I'm a desperate "just after july 1" member.
It would be bodacious if I could order the Pinebook Pro now; for the manufacturer's longer term planning and for my state of mind.
Or do I not exist without a coupon?
Don't worry about it. I'm still waiting for my coupon. The first batch won't even have the ANSI keyboard, so don't consider these preorders to be a proper release of the laptop.
(07-27-2019, 05:04 AM)DoMiNeLa10 Wrote: so don't consider these preorders to be a proper release of the laptop.
Such kind words for the staff that worked hard to make the Pinebook Pro a reality...
(07-26-2019, 08:59 PM)binarian Wrote:
(07-18-2019, 07:12 AM)mamboman777 Wrote: Greetings! I'm planning on purchasing a PBP.  I would like to use it as a daily work machine for email and web browsing, but I'm curious if it may be usable for my side gig.  I am a recording engineer.  I would need it to run jack+ardour to record up to 16 track simultaneously @ 44.1k. Does anyone see any reason this won't work? The storage world be a concern. I would probably place sessions and tracks on USB drives.
Audio recording in and of itself isn't a cpu-heavy task, so while the PBP doesn't have a ton of horsepower it will probably handle that alright.  Make sure your storage device can handle the throughput though.
Doing editing, however, is not something I would recommend.
Editing, or even any plugins at all is not part of the plan.  I just want to write to disk.  Everything else would be done at home on a different machine.
Are there throughput limitations for the PBP usb?  Focusrite gear all runs on USB 2.0, so I would probably consider using the USB 3 port on the pbp for the storage. I have recorded stuff like this to an sd card before, so I'm hoping there's not going to be much of a problem.
Just confirming if the power supplies for the pinebook pro will be "switching"? I'm wanting to order for use in Australia. Currently I see USA and EU adapters only. Can I simply order either USA or EU and use a travel adapter or will you be offering other connections (e.g. AU).
Many thanks
(07-28-2019, 06:47 AM)cocozozo Wrote: Just confirming if the power supplies for the pinebook pro will be "switching"?  I'm wanting to order for use in Australia. Currently I see USA and EU adapters only. Can I simply order either USA or EU and use a travel adapter or will you be offering other connections (e.g. AU).
Many thanks
Yes, all the power adapters can run on any line voltage. There also is a AU plug available with this one: https://store.pine64.org/?product=rock64...uk-us-plug
Many thanks
Ok thats fantastic.
Cheers Smile
I would not expect any issues then.  AFAIK the only throughput "limitations" on the PBP is the fact that the camera/mic are USB (and I assume the keyboard/trackpad are too), but those are inconsequential.  If I did my math right, 16 channels of 48k 24bit audio is only 18Mbps, and standard USB2 spec supports a theoretical max of 480 Mbps, so you're well within range.  I didn't know if an SD card would support that, but certainly any hard drive should, let alone eMMC or SSD
A class 10 (10 MB/s) SD card should be able to handle that. One word of caution, once an SD card gets too fragmented, performance can drop significantly.
https://www.sdcard.org/developers/overview/speed_class/
I've experienced that. I've also moved away from SD cards. I'm planning on putting my sessions on external USB drives or nvme.
I bet your math is correct on the io.  Probably why Focusrite doesn't bother with usb 3.0 compatibility. For those interested: https://support.focusrite.com/hc/en-gb/a...vs-USB-3-0
  Updated Pinebook Pro? tantamount 2 1,735 06-20-2026, 10:14 AM
Last Post: tantamount
  Pinebook pro bricked? michaelmoua 4 7,389 05-26-2026, 02:20 AM
Last Post: Anthona
Thumbs Up Finally got Kali working on my Pinebook Pro! qingss0 0 1,451 04-04-2026, 08:00 AM
Last Post: qingss0
  dead Pinebook - help please RicTor 3 2,740 03-26-2026, 04:22 PM
Last Post: williamcorlin
  Pinebook problem meghancordo 2 6,203 03-18-2026, 08:58 AM
Last Post: RicTor
  Pinebook Pro in EU for Sale - €90 jan_vdk 5 9,978 02-09-2026, 12:50 AM
Last Post: Anthona
  Pinebook Pro for sale rfm83 0 1,641 11-08-2025, 09:22 AM
Last Post: rfm83
Question Full desktop Surfing and Absolute Privacy on the pinebook? Www 1 8,397 08-02-2025, 08:55 PM
Question Printing and scanning documents with pinebook? Www 0 4,897 06-28-2025, 01:25 AM
Last Post: Www
  Use SD to install new OS over pinebook debian Rudy558 10 28,766 03-09-2025, 11:17 AM
Last Post: davisthomas
Users browsing this thread: 30 Guest(s)
