SPI support in GPIO
Hi!
I recently bought a RockPro64 with 4GB and would like to control a 1.8 LCD screen with SPI interface using the pins on the GPIO header.
The system is running ayufan's Ubuntu minimal.
I had success in simple GPIO switching by using the RP64-GPIO library:
https://forum.frank-mankel.org/topic/292...-rp64-gpio
However, I was not able to access SPI. I could not find any help or documentation on the internet, not even on the Wiki.
Anyone had success with this?
SPI is exposed by default on my builds, as you use also SPI flash.
It is very likely that there's a driver for your LCD screen, but I'm unsure if this is compiled in.
Homepage: https://ayufan.eu
Releases:
Rock/Pro 64/Pinebook Pro: Linux; Chromium OS
So/Pine A64/Pinebook: Linux; Android 6.0; Android 7.1
Buy me a Beer
(07-05-2019, 02:53 PM)ayufan Wrote: SPI is exposed by default on my builds, as you use also SPI flash.
You'd need to create a device tree overlay that describes your device, and hooks up a driver to it.  I don't know how to specify the chip select line (the one on pin 24 of the PI2 bus is already consumed by the SPI flash and should not be used), and have asked in another thread how to do this.
  Mainline U-Boot with SPI, NVMe and SATA boot support sigmaris 108 226,443 09-25-2023, 12:46 AM
Last Post: ChriChri
  setting permissions on gpio baraqiyal 0 2,900 08-16-2022, 11:37 AM
Last Post: baraqiyal
  Support says "regulator" on the SBC burned out; how to fix? dmos 0 4,080 06-02-2022, 02:20 AM
Last Post: dmos
  No Hardware Interrupts for GPIO pantera 2 8,031 05-08-2021, 10:16 AM
Last Post: Badger
  Using GPIO pins smartdave 12 31,824 02-08-2021, 01:49 PM
Last Post: {-DesT-}
  Camera sensor support on MIPI lines abhimanyu_gr 0 3,271 01-22-2021, 09:23 AM
Last Post: abhimanyu_gr
  USB Type-C Display cable support (for 2 in 1: Video + Power) Paprika88 0 3,995 02-12-2020, 06:47 AM
Last Post: Paprika88
  rockpro64 support in the rockchip uboot dedoz 0 3,485 01-13-2020, 01:51 PM
Last Post: dedoz
  Vulkan support with rockpro64 rahulsharma 2 7,877 08-21-2019, 10:34 PM
Last Post: rahulsharma
  Camera support for linux image in rockpro64 rahulsharma 1 4,931 01-26-2019, 09:48 AM
Last Post: anykey
