Debian 10 (Buster) in deep freeze - includes support for Pine64+
For those not following Debian development Buster (Debian 10) is now in deep freeze and will most likely be released in the following months.
I have been running it on a Pine64+ for the past months and it's quite usable for me.
Works for me:
  • HDMI video output at 1920x1080 (tested console only, most likely framebuffer)
  • USB (both ports)
  • Ethernet at GBit speeds
  • Watchdog (i.e. the logs show it is being enabled)
Problems encountered so far:
  • slightly unstable, apparently more so when (lots) of USB stuff connected to it
  • occasional clock jumps to the future (95 years?)
As this is mostly a headless system (I'm using the HDMI output only occasionally for debugging) I did not test other features.
Have fun with Buster Big Grin
That is pretty awesome Smile
(05-01-2019, 02:34 AM)amp Wrote: [*]occasional clock jumps to the future (95 years?)
This has been fixed in Mainline with "CONFIG_SUN50I_ERRATUM_UNKNOWN1=y" as well as in DT with " allwinner,erratum-unknown1;" in timer node.
According to https://linux-sunxi.org/Linux_mainlining...d_into_5.1 in 5.1, while Buster will release with 4.19.
I'll be upgrading 5.1 as soon as available in the Debian experimental archive (currently has 5.0 only) as I'm not into compiling stuff  Wink .
Typically Debian provides newer kernels also via the backports archive, but this will not happen before the release.
As of today the kernel in Buster includes the fix.
dmesg | grep erratum
[    0.000000] CPU features: enabling workaround for ARM erratum 843419
[    0.000000] CPU features: enabling workaround for ARM erratum 845719
[    0.000000] arch_timer: Enabling global workaround for Allwinner erratum UNKNOWN1
You need to have at least linux-image-4.19.0-5-arm64, version 4.19.37-3 (based on Linux mainline 4.19.37).
(05-01-2019, 02:34 AM)amp Wrote: Hello,
Works for me:
  • USB (both ports)
Just in case you missed it, Buster has been released on 6.July, including the fix for the clock jumps (as mentioned above).
  ROK OS v7 OK Bitcoin Fullnode OpenBazaar for Pine64+ OKtoshi 9 27,916 05-21-2021, 12:14 PM
Last Post: killor
  lost eth0 on my pine64 psarazin 7 16,160 03-22-2021, 05:55 PM
Last Post: kuleszdl
  Debian installer on Pine A64+ but no hdmi mrwick 1 9,120 07-28-2020, 01:49 PM
Last Post: kuleszdl
  Debian Pine64 h264/5 Video under vlc ozcy 6 20,627 04-15-2020, 05:27 AM
Last Post: dmitrymyadzelets
  OMV/debian/systemd: how to start the network kittyland 0 5,579 12-10-2019, 05:29 PM
Last Post: kittyland
  Pine64 Debian Stretch/mainline [4.14.7] CallMeFoxie 50 166,721 07-22-2019, 09:24 PM
Last Post: amp
  Installing Debian with the Debian Installer (Buster RC1) amp 1 8,462 06-28-2019, 12:35 PM
Last Post: Kaarme42
  Script to build pure Debian images for Pine64+ amp 1 7,815 05-01-2019, 09:09 PM
  Debian (Stretch) for Pine64-LTS wgray 2 11,122 04-04-2019, 09:54 PM
Last Post: wgray
  Is there just one fuctioning Debian Desktop image? KNERD 7 21,289 03-29-2019, 02:00 AM
Last Post: desai_amogh
