Q4OS for PINEBOOK
#71
@pineadmin
Thanks for the update.
Nonetheless, new Q4OS for Pinebook 1080p image revision ".r5" has been just released, and the legacy Pinebook image has been updated as well.
See the official Q4OS downloads page:
https://www.q4os.org/downloads1.html#downloads_spechw
Setup guide:
https://q4os.org/dqa013.html
Tweet:
https://twitter.com/q4osteam/status/1061026146706432000
#72
(11-09-2018, 04:32 PM)q4osteam Wrote: @pineadmin
See the Q4OS downloads page:
Official downloads site:
Direct download links:
Pinebook 1080p:
https://sourceforge.net/projects/q4os/fi...80p.r5.zip
Pinebook legacy:
https://sourceforge.net/projects/q4os/fi...ook.r5.zip
Setup guide:
Tweet:
Thank you for the update.
We will test it and added to Wiki and Pine64 Installer.
#73
Updated Q4OS (Pinebook) 2.4-r5 on Wiki and PINE64 Installer.
Added Q4OS (1080P Pinebook) 2.4-r5 on Wiki and PINE64 Installer.
#74
I just got my Pinebook 1080p and it's running Q4OS, which is much faster then the Ubuntu with KDE Neon that was installed by default.
I'm happy with the fact that it runs PHPStorm, Oxygen XML (I use 14) with the openJava jdk that is available in apt repo.
I find video playback with vlc and YouTube in chromium a bit sluggish,
it's a good system, I got it looking kind of like Mac OS classic (i can't get it to look exactly like OS9)
Working as a Film Electric and I have been using Linux since around 2002.
Like to play with Python and Jupyter Lab/Notebooks when not going to the park with my baby girl.
#75
Q4OS for Pinebook 1080p image revision ".r6" has been released. The key change is an adoption to the 1080p resolution, so the fonts and icons sizes has been increased.
Direct download link, Pinebook 1080p:
https://sourceforge.net/projects/q4os/fi...80p.r6.zip
Setup guide:
#76
Updated Q4OS (1080P Pinebook) 2.6-r6 on Wiki and PINE64 Installer.
#77
(11-21-2018, 09:59 AM)q4osteam Wrote: Q4OS for Pinebook 1080p image revision ".r6" has been released. The key change is an adoption to the 1080p resolution, so the fonts and icons sizes has been increased.
Setup guide:
On KDE Neon I am able to play 720p at 50-60% cpu for mpv, and mplayer seems to be configured for "gpu" but on q4os it does not seem to be able to play via gpu or even via vdpau drivers?
#78
rookieone
Hardware video acceleration doesn't work so far, however it should be enabled within some forthcoming Q4OS release. Anyway, you can install Q4OS on top of Armbian Stretch at the moment, see https://www.q4os.org/dqa012.html . Armbian Pinebook edition should be able to use hardware video acceleration https://www.armbian.com/pinebook-a64/
It would be helpful, if you would post back a result.
#79
(12-05-2018, 05:30 AM)q4osteam Wrote: rookieone
What I understand here in Armbian forum is that hw video acceleration is not working on Armbian Stretch, which has mainline kernel 4.19.y, or do I not understand correctly?
#80
Well, video acceleration probably doesn't work on Armbian. If so, the Q4OS will not be able to use it as well. You could still try to install the latest Q4OS ".r7" release https://q4os.org/downloads1.html#downloads_spechw , and enable sunxi drivers: "sudo pine64_enable_sunxidrm.sh"
  DietPi OS for Pinebook MichaIng 5 16,835 07-28-2026, 08:02 PM
  Irradium (based on crux linux) Pinebook A64 (aarch64) mara 4 14,468 05-18-2026, 02:11 PM
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 103,210 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 5,827 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 4,404 07-10-2023, 07:44 AM
  Pinebook no longer boots rjtanner 12 16,447 04-13-2023, 01:09 PM
  Stock Debian on original Pinebook moonwalkers 1 8,353 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 10,602 01-04-2022, 09:22 PM
Last Post: irongarment
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 11,302 05-07-2021, 10:20 AM
  pinebook.kde.org.uk no longer has release file?? supermassive 1 8,431 01-20-2021, 11:18 AM
