ClusterBoard questions (eMMC, consoles, etc.)
Question
I've been looking at the Wiki and through the threads here and have a couple of questions on the ClusterBoard I have just received:
1) the eMMC slot maps to the SOPINE module in slot 0, correct? The other slots cannot be connected to the eMMC?
2) where does one connect the serial console for the SOPINE modules? I bought the serial console "PINE64 USB SERIAL CONSOLE/PROGRAMMER" but where should I connect it to access the consoles of the SOPINEs?
3) reading the threads it seems that heat is an issue: I bought my three SOPINE modules without heatsinks - is the ROCK64 / PINE A64 / PINE H64 Heatsink OK for the SOPINE?
4) are there pins on the ClusterBoard where one can connect fans (see 3 above)? Should they be powered independently or is there somewhere to pick up a 5V supply off the main PSU?
I plan to run my ClusterBoard as the "CPU cluster" off a Rock64Pro NAS providing disk space so thermal issues are important for me.
Thanks,
Arrigo
(@cynicalsecurity on Twitter)
i think there are some clusterboard folks on chat that don't read the forums much. check out the chat by clicking on chat at top of page.
dkryder is probably correct. You may wish to reach out to Xalius or maya in the IRC chat.
(11-05-2018, 06:26 AM)Luke Wrote: dkryder is probably correct. You may wish to reach out to Xalius or maya in the IRC chat.
OK, I assume it is a normal IRC channel, don't really want to connect via web when I am comfortable using irssi. I assume I just take the details from the link under your signature?
  Managed Ethernet switch on the Clusterboard dsimic 6 16,282 01-16-2024, 02:05 AM
Last Post: hazcam
  Selling Clusterboard + 4 sopine xblack86 7 14,124 09-26-2022, 03:09 AM
Last Post: poVoq
  clusterboard availability? linear 1 5,353 07-17-2022, 06:44 AM
Last Post: poVoq
  Clusterboard not getting IP address after network fix Norlark 14 27,437 08-30-2021, 05:00 PM
Last Post: poVoq
  When would be the Clusterboard back on stock? __kzl__ 5 11,877 08-16-2021, 03:52 AM
Last Post: poVoq
  Schematics for customising the Clusterboard TechDragon 0 5,516 05-25-2021, 10:28 AM
Last Post: TechDragon
Information Clusterboard Guide AZClusterboard 9 35,068 04-06-2021, 06:32 AM
Last Post: poVoq
Brick Clusterboard CAD drawings TeaPack 1 6,806 03-31-2021, 01:38 PM
Last Post: Pine
  New Clusterboard Setup wargfn 5 14,176 01-01-2021, 10:10 AM
Last Post: poVoq
  eMMC AZClusterboard 8 18,556 11-13-2020, 03:28 PM
Last Post: hvdkooij
