PCIe SSD drive still not working ??
Sorry if I'm being totally stupid and posted in wrong area, but...
I've just received a new production unit (Rockpro64 V2.1 2018-06-06) together with a PCIe 3.0 x4 to M.2 (NGFF) SSD Adaptor, to which I've added a WD blue SSD M.2 2280 drive.
I'm using Ayufan's latest builds, both minimal & full, but nothing I try allows access to the drive.
The boot logging shows an error connecting to the PCIe device(s), but I'm not sure what is going on (sorry but I'm unable to upload file).
The drive I've tested in a normal PC & can create\format partitions etc...
Reading other posts on the site, relate to a resistor that needs to be removed ?  but I was under the impression that the board I purchased was one of the new 'fixed' ones, so should work ok ??
Any thoughts or suggestions gratefully received....
Please read http://irc.pine64.uk/?date=2018-08-05T14:36:00.000Z Start @ 05/08/18 11:09 #Rock64
1. Quartz64 Model B, 4GB RAM
2. Quartz64 Model A, 4GB RAM
3. RockPro64 v2.1
https://linux-nerds.org/
(08-07-2018, 01:17 PM)dr_ju_ju Wrote: ...
You're clear after reading the IRC log, that your device is a SATA interface SSD in an M2 form factor, not an M2 NVME drive, right?
You can either get an NVME drive or much more cheaply get the SATA adapter in the store.
(08-07-2018, 02:47 PM)Bullet64 Wrote: Please read http://irc.pine64.uk/?date=2018-08-05T14:36:00.000Z Start @ 05/08/18 11:09 #Rock64
Is that the correct date\time ? as I see nothing starting @ 11:09, unless I'm being totally thick today, as usual..
In short - WD Blue are SATA interface and will not work on the M2 PCIe adapter from Pine64.
The ROCKPro64 supports NVMe drives via the M2 PCIe adapter - if you stick to WD you need Black.
M2 SATA drives have a Key B (as well as M), NVMe have Key M only.
(Or you could try find a PCIe adapter like mine - I havent tried any SATA on this card yet Smile )
Blush My bad & yes being stupid, for not checking specs properly
I have an NVMe drive, but plugged in the SATA one instead and ploughed on regardless
I'm also going to try a dual sata interface card, as I need lots of storage for a travelling Astrophotography control & imaging system, and the less I have to rely on USB connected storage the better...
I am new to pine64. Just bought ROCKPro64 and waiting for shipment. In the meantime I have a question: do you think it will work with this PCIe to M.2 adapter:
https://www.aliexpress.com/item/H1111Z-A...60990.html
and this SSD drive (not NVMe):
https://www.aliexpress.com/item/Kingsuxi...46435.html
I want this because this SSD is still cheaper than NVMe (I know it is also slower). Is this possible or I must go with NVMe?
Thanks.
(04-10-2019, 01:50 PM)Kokum Wrote: Hello,
Thanks.
If you plan to use the above combination, you need to have a n USB-Sata adapter and feedback the Sata connection to the adapter board. The above PCIe adapter don't have onboard PCIe to Sata circuit, it just have the m.2 connector that passive link to SATA connector.
  power button not working Vista8720 0 3,409 05-07-2024, 11:26 PM
Last Post: Vista8720
  Installing Wifi drive for the RockPro64 John45595 0 4,718 02-10-2024, 11:32 PM
Last Post: John45595
  Cant get rockpro64 working brasilikum 3 8,533 03-19-2023, 06:22 AM
Last Post: runyor
  RockPro64 Stopped working WarpLover 5 9,449 02-06-2023, 10:10 AM
Last Post: diizzy
  PCIE interface power on too late Slark Xiao 0 3,001 11-29-2022, 11:56 PM
Last Post: Slark Xiao
  After Power Loss feature working bdherouville 2 6,042 08-22-2022, 03:52 AM
Last Post: bdherouville
  Booting my RockPro64 from NVMe drive PsySc0rpi0n 4 10,645 05-11-2022, 02:35 PM
Last Post: PsySc0rpi0n
  PCIe gen1 timeout - how to debug tosi 3 10,153 03-10-2022, 05:06 PM
Last Post: db579
  Anyone try an NVIDIA GPU in the PCIe slot? Paraplegic Racehorse 0 3,387 04-15-2021, 11:46 AM
Last Post: Paraplegic Racehorse
  Never ever mix up CPU board connector with 8-pin PCIE connector LMM 0 3,420 02-11-2021, 10:18 AM
Last Post: LMM
