Won't power on/boot -- kickstarter A64 2GB
Kickstarter backer, finally getting to playing with my A64+ 2gb
Using the new Etcher image burner on a Transcend 300x 16gb card UHS-1
No matter what image I use (Android, Linux, RemixOS, etc.), won't boot.
Power supply is a 5V 2.5A power supply I use with my Raspberry Pi 3 which works fine
Symptoms:
Red LED works/on when USB power is plugged in
HDMI out makes the monitor turn on, then off because 'no signal is detected', turns back on, turn off no signal -- keeps repeating
I'm unsure if this is power supply, memory card, or simply bunk A64 related.
Any help?
(09-22-2017, 02:09 PM)fuzzycuffs Wrote: Kickstarter backer, finally getting to playing with my A64+ 2gb
Symptoms:
Any help?
I have the same issue. Did you get this resolved?
Symptoms:
Any help?
in general, mostly due to power supply (make sure is 5V 2A, don't use smartphone charger) and microSD card preparation.
Please review the wiki NOOB section: http://wiki.pine64.org/index.php/NOOB
Issue resolved.
  Pine a64+ power supply davidspencer 0 2,901 03-18-2026, 01:02 AM
Last Post: davidspencer
  PINE A64 SBC: Clone of a functional 32GB SD card doesn't boot burningkrome 3 7,229 05-19-2023, 07:43 AM
Last Post: crocspot
  Pine A64 does only boot with Android 5.1 Dude 6 11,564 07-03-2022, 02:18 PM
Last Post: Dude
  Pine A64+ vs LCD do not boot DDS 3 11,675 02-23-2021, 05:33 PM
Last Post: thedu
  Pine64+ power button PaddyChan 0 5,907 09-14-2020, 09:55 AM
Last Post: PaddyChan
Exclamation Can't boot when SD card inserted kivox 5 13,694 03-15-2020, 06:00 AM
Last Post: kivox
  Boot from HDD via usb BnEc 1 6,187 11-29-2019, 04:39 AM
Last Post: evilbunny
  UK power supply (Pinebook Pro 64) skobi 0 4,024 11-17-2019, 04:55 AM
Last Post: skobi
  Pine A64 stuck in boot process joey 1 5,937 05-28-2019, 09:07 PM
Last Post: joey
  boot loop with lcd plugged in drock 0 3,734 01-09-2019, 01:37 AM
Last Post: drock
Users browsing this thread:
