Clusterboard Feature request topic
I couldn't find one anywhere else on this forum; maybe it's a good idea to have a feature request topic since I believe it is a prototype and thus still in development?
Things I'd love to see changed:
- A second ethernet switch, to serve as an ethernet backbone between the SOPine modules, for inter-module traffic (cluster/config sync/HA traffic, front/backend separation, etc).
- A physical connection to that backbone switch so you could connect multiple clusterboards and have modules from different boards directly interact without using up bandwidth on the main switch
- A different placement of the pin headers for the modules, these aren't accessible when a heatsink is applied.
- A step-up converter to 12V and Pin header for a cooling fan (so you can simply use one powersupply and don't need a seperate one for the fan).
- Some form of individual remote control; remote power/reset functions, serial over ethernet type functionality
If this kind of feedback is unwanted, go ahead and close the topic Smile
(03-14-2018, 05:43 AM)PeterKeuning Wrote: I couldn't find one anywhere else on this forum; maybe it's a good idea to have a feature request topic since I believe it is a prototype and thus still in development?
There are a good number of 5v fans on the market - including good quality quiet ones from Notua...
I'd like the functionality to create a BMC or management node for the cluster board. The primary features being:
- Each node's console UART connected to something like a pair of FDTI FT4232H USB-4xUART, or exposed via compatible headers for: http://www.ftdichip.com/Products/Modules...2H-56_Mini
- The reset pin for each node connected to a relay or similar, ideally with a controller exposed via an external facing USB device.
- Not sure if its possible with the SOPIN's pinout, but ability to out-of-band flash the SPI on a node.
USB is nice for each of these as for development you can loop it back to the first node on the clusterboard. Then for scaling up, say with 6 clusterboards, you could connected each into a hub, and have a single Pine64-LTS have access too all the UARTs and have remote power cycling ability.
Looking further out, upgrading the embedded switch with a 10GBase-T uplink and some amount of management functionality would be useful. The management functionality would allow SDN like work.
Dual Ethernet sounds good.  Then a clusterboard can be clustered.
+1 some sort of management controller and more network throughput in/out of the clusterboard. I'd also welcome more local storage options, not that there'e much real estate left for an eMMC per module...
  Managed Ethernet switch on the Clusterboard dsimic 6 16,985 01-16-2024, 02:05 AM
Last Post: hazcam
  Selling Clusterboard + 4 sopine xblack86 7 14,644 09-26-2022, 03:09 AM
Last Post: poVoq
  clusterboard availability? linear 1 5,577 07-17-2022, 06:44 AM
Last Post: poVoq
  Clusterboard not getting IP address after network fix Norlark 14 28,461 08-30-2021, 05:00 PM
Last Post: poVoq
  When would be the Clusterboard back on stock? __kzl__ 5 12,310 08-16-2021, 03:52 AM
Last Post: poVoq
  Schematics for customising the Clusterboard TechDragon 0 5,685 05-25-2021, 10:28 AM
Last Post: TechDragon
Information Clusterboard Guide AZClusterboard 9 35,744 04-06-2021, 06:32 AM
Last Post: poVoq
Brick Clusterboard CAD drawings TeaPack 1 7,044 03-31-2021, 01:38 PM
Last Post: Pine
  New Clusterboard Setup wargfn 5 14,628 01-01-2021, 10:10 AM
Last Post: poVoq
  Clusterboard does not even turn on? poVoq 3 10,962 08-15-2020, 07:31 AM
Last Post: poVoq
