Flakey WIFI (problems authenticating, etc.)
I'm running the latest release on eMMC and having repeated problems with WIFI that go beyond the suspend/resume applet stuff.
Conecting/authenticating to my home network (WPA2) is hit or miss with Pinebook, despite being int he same room as the access point. I'm having to repeatedly restart the network manager, etc. It seems to me like teh authentication process is maybe timing out, even though the signal is strong and credentials are correct.
Are others encountering similar issues? If so, what solutions or work-arounds have you employed?
This is getting pretty frustrating. It's hit or miss whether I'm going to be able to connect to what is a quite robust home network when I boot up the PB.
Sometime there's no connection. Sometimes there are multiple attempts to connect... with multiple dialogu
es asking me to type a password.
Of note, when I go to look at/edit past connections I see a weird numbered list. The SSID is just 'NETGEAR30'. The list of past connections is something like 'NETGEAR30 4, NETGEAR30 5, NETGEAR30 6'. Each showing that it was never connected to.
I have seen this reported but I have not experienced it myself (11'' Pinebook), despite connecting to a number of different access points. Perhaps this is trivial, but have you tried changing the wifi channel ?
I'll give that a shot, at least as an experiment.
I've had some luck connecting via 'nmcli', no joy at all since last night when it comes to the network manager/aplet... so the plot thickens.
(07-01-2017, 06:30 PM)robbiemacg Wrote: This is getting pretty frustrating. It's hit or miss whether I'm going to be able to connect to what is a quite robust home network when I boot up the PB.
Same problem detected here, sometimes it refuses to authenticate, sometime it works flawlessly...
How did you manage the problem?
Regards,
I'm having similar issues with wifi. When I initiate the connection the signal is strong. After the connection is made the signal drops by half, but it works fine for a few minutes, after which it becomes practically useless. Disconnecting and reconnecting starts the process over again.
Typical Bananaware..
also does not work here and still no fix after months..
  Wifi doesn't work correctly Fredric92 1 8,368 08-10-2021, 08:39 AM
Last Post: Jean-Marc LACROIX
  Wifi I/F on Pinebook 11.6" eblot 2 7,053 05-19-2019, 04:53 PM
Last Post: Shoananas
  Problems putting Ubuntu (Xenial Mate) on my replacement eMMC. frank-zappa 11 24,786 05-01-2019, 12:09 PM
Last Post: frank-zappa
  KDE Neon problems persisting (1080) ImmortanJoe 8 15,971 11-18-2018, 02:22 AM
Last Post: ImmortanJoe
Music Problems using Spotify Web version because DRM (Firefox & Chromium) Ekkaia 6 15,553 09-07-2018, 02:23 AM
Last Post: JerrySmith1021
  WiFi on Xenial Minimal soupbowl 3 8,421 08-12-2018, 07:54 AM
Last Post: jblakeharris
  Problems to install qemu on Xenial Mate (for EMMC) demian 1 5,560 03-14-2018, 08:43 AM
Last Post: xalius
  Wifi applet after resume from suspend Luke 13 25,830 10-01-2017, 05:26 AM
Last Post: maya.b
Information How to manage Wifi in xenial-i3 i3wm image UPDATE MarkHaysHarris777 4 10,831 09-14-2017, 12:12 AM
Last Post: dahni
  Problems At Shutdown? robbiemacg 10 19,915 08-25-2017, 10:20 PM
Last Post: MarkHaysHarris777
