Android 6.0 Tablet and TV (release candidate, maintained)
Maybe, we will see.
Homepage: https://ayufan.eu
Releases:
Buy me a Beer
(05-13-2017, 09:39 AM)ayufan Wrote: sfatlind09: please try this latest build: https://github.com/ayufan-pine64/android.../tag/0.3.5
Does also not work i have selected 1080p50 and 1080p60 bought are not working at all.
Gesendet von meinem SM-T580 mit Tapatalk
Are you sure. I tested that today and I were able to use different resolutions.
Releases:
Buy me a Beer
(05-13-2017, 01:55 PM)ayufan Wrote: Are you sure. I tested that today and I were able to use different resolutions.
May you can edit the file and send it to my email?
Fatlind09@icloud.com
hdmi cec is not working i've attached the dmesg ouput.
I see some input received but not a lot is there something extra i have to do for getting it to work on my sony tv?
.txt   dmesg.txt (Size: 89.63 KB / Downloads: 842)
I worked with some of the folks in the IRC on my mouse not working. I was able to get it working by creating a new burn of Android 6 using the Pine installer. Everything is good now.
How can I increase the storage with a 128GB sd card? It only shed like a 64GB card and gives me a corrupted sd card message on latest build
(07-07-2017, 08:25 PM)pytyper483 Wrote: How can I increase the storage with a 128GB sd card? It only shed like a 64GB card and gives me a corrupted sd card message on latest build
Read this link, to detect fake SD card:
There are many fake SD cards on the market;  we recommend :
Samsung Evo Plus Class 10 32G ;  from a reputable source, no cheap imitations from China.
Blush
I have tried up to 200GB microSD card. You can increase the storage with 128GB microSD card.
(02-28-2017, 05:58 AM)Traveler Wrote: I was always told you couldn't switch back and forth as I had wanted to that so I could use it as a tablet then when needed connect it to the TV. Lack of audio probably has something to do with HDMI audio passthrough since it detected LCD connected. Maybe Auyan will come in a teach us something.
Someone mentioned Netflix. I use Sony Playstation Vue and it requires a non rooted version of Android. All the root cloakers I used did not work. Root Cloak is designed for phone use and would clip off the right side of the APP so I could not see the "+" symbol to add APPS.
@Traveler. Any luck with Playstation Vue? I also use. I've tried several versions of android for pine, including non-rooted (rootable) versions but so far no luck. Has anyone else tried this or have any suggestions for using Pine with Playstation Vue?
  Need help compiling android for pine a64 + YeeticusMaximus22 2 2,049 08-20-2026, 08:45 AM
Last Post: ahegarosib97
Shocked Remote for Android? liodra 18 48,735 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 31,084 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 12,290 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 13,704 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 10,223 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 6,505 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 397,934 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 7,240 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 158,329 02-10-2019, 07:44 PM
Last Post: mmmarcus
