Android 6.0 Tablet and TV (release candidate, maintained)
#51
why is "disp_mode=1080p60" always uncommented?
I found out my problem.
In the "uEnv.txt" file, "disp_mode=1080p60" is missing the space just before "disp". I added the space to before it and HDMI works now. To be clear, "disp_mode=1080p60" should be changed to " disp_mode=1080p60".
Matt
#52
Bluphire: this is default, maybe you have a problem with your text editor?
Homepage: https://ayufan.eu
Releases:
Buy me a Beer
#53
can you make a stock image of 6.0?
thx
#54
(12-04-2016, 12:39 PM)ayufan Wrote: Anyone opt-in to try ATV fix: https://github.com/ayufan-pine64/android.../tag/0.3.1?
I will try it as soon as I get a chance, probably end of this week.
#55
trenton4k: this is done already if you download image without `-tv`.
Releases:
Buy me a Beer
#56
First of all thanks for all your hard work on this ayufan. You did a great job!
I've just opened an issue on the issue tracker regarding mounting external USB drives: https://github.com/ayufan-pine64/android-6.0/issues/2
I haven't been able to mount any USB storage device with this image. I've tried several partition types (ext3, ext4, fat32, ntfs) using both MBR and GPT partition tables with no luck. I've tested releases 0.3.0 and 0.3.4 and both have the same result.
Anyone else experiencing this issue?
PS: I'm using an USB 3.0 external hard drive plugged in an USB hub which is connected to an external power source.
#57
I tried 0.3.4-r18 and the android remote appears to be working now.
#58
Hi
Does a wifi dongle or a ethernet cable work with this os?
thanks
#59
(12-11-2016, 08:07 AM)Commander_Monkey Wrote: Hi
thanks
it work on  ethernet at 100mbite (what i use it at)
#60
Commander_Monkey: both do work OK
Releases:
Buy me a Beer
  Need help compiling android for pine a64 + YeeticusMaximus22 2 2,049 08-20-2026, 08:45 AM
Last Post: ahegarosib97
Shocked Remote for Android? liodra 18 48,735 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 31,084 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 12,290 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 13,704 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 10,223 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 6,505 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 397,936 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 7,240 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 158,330 02-10-2019, 07:44 PM
Last Post: mmmarcus
