how to install Wifi/Bluetooth module
Hi
I now have my pine64plus broad and need to know which way to install Wifi/Bluetooth module on it
because module the fits both ways
Have looked for a photo that shows this
Look closely at the pins on the board and the connectors on the module. They are offset slightly. It will only go on one way with all the pins being used. Note the location of the antenna on the module itself in the picture below:
[Image: Screen%20Case%204_zpsmaveyezq.jpg]
(10-08-2016, 09:16 PM)Bluphire Wrote: Look closely at the pins on the board and the connectors on the module. They are offset slightly. It will only go on one way with all the pins being used. Note the location of the antenna on the module itself in the picture below:
Thank you!!
  Wifi dongle issues Deckard 2 3,048 01-13-2025, 12:34 PM
  linux-headers and quartz64-post-install package conflicts Berzerkleyfan 2 4,978 12-01-2023, 05:17 AM
Last Post: Berzerkleyfan
  USB adapter to eMMC module not recognized danril 0 3,229 11-25-2022, 04:16 AM
Last Post: danril
  PBP Debian 11 GRUB install error zlth 2 4,910 11-18-2022, 07:42 AM
Last Post: zlth
  SOQUARTZ Compute module W does not fit Raspberry Pi CM4 dev board ihab 0 3,379 10-06-2022, 08:46 PM
Last Post: ihab
  Wi-Fi/Bluetooth for PINE64, Model: Sopine A64 lamson 0 3,747 08-24-2021, 08:17 AM
Last Post: lamson
  No WIFI network discovery in any manjaro installation (but works on fedora) pineitup 1 5,612 02-02-2021, 12:13 AM
Last Post: PineSupporter
  Cannot charge and NO Wifi? jiapei100 3 8,653 06-27-2020, 02:11 PM
Last Post: jiapei100
  wrong launguage install chadace 1 6,339 06-08-2020, 08:31 PM
Last Post: chadace
Bug WiFi enabled but refuses to connect cardboardmaster 6 13,584 06-02-2020, 11:56 PM
Last Post: pfeerick
