Debian on Pinebook Pro
What is the state of USB Type C DiplayPort out on Debian 12 for the Pinebook Pro?  It seems like all the required kernel modules are loading, but it doesn't work.  Is this a Debian 12 kernel issue or a U-Boot Issue?
Do you have `firmware-misc-nonfree` installed?
Yes.
firmware-misc-nonfree is already the newest version (20230210-5).
If you run `dmidecode`, does it tell you what u-boot version you're using?
Can you try a Stable-backports kernel and see if that changes/improves the situation (currently version 6.6.13-1~bpo12+1) ?
# dmidecode 3.4
# No SMBIOS nor DMI entry point found, sorry
$ uname -r
Linux PinebookPro 6.1.0-18-arm64 #1 SMP Debian 6.1.76-1 ( 2024-02-01) aarch64 GNU/Linux
Is the correct backport repo "http://deb.debian.org/debian bookworm-backports main contrib non-free non-free-firmware" ?
"typec_displayport" is the correct Linux kernel module to have loaded?
(03-22-2024, 09:46 AM)u974615 Wrote: # dmidecode 3.4
Bummer
Quote:$ uname -r
Linux PinebookPro 6.1.0-18-arm #1 SMP Debian 6.1.76-1 ( 2024-02-01) aarch64 GNU/Linux
Are you sure that isn't 6.1.0-18-arm64? Note the arm64 part.
Quote:Is the correct backport repo "http://deb.debian.org/debian main contrib non-free non-free-firmware" ?
No, that's the normal repo. For backports see here: https://backports.debian.org/Instructions/
(03-22-2024, 10:58 AM)u974615 Wrote: "typec_displayport" is the correct Linux kernel module to have loaded?
I think so, but I don't know.
USB Type C Alternate Mode DisplayPort out on the PineBook Pro doesn't even work with the PINE64 Dock.
I gather that USB Type C Alternate Mode Displayport out is no longer supported in Debian Workstation 12 aarch64, at least for the PineBook Pro.
I imagine the backstory as to why it was demonstrated to work and why it doesn't now would be intriguing. Of course the demos I saw were for Manjaro and not Debian and wasn't using Tow-Boot.
I can see that this is a difficult feature to do. Google can't even get it to work on the Pixel Phone and Pixel Tablet. Whereas Samsung Galaxy phones have had it for years.
  Boot Order in Pinebook Pro food 12 18,387 05-25-2026, 08:28 AM
Last Post: finmark
  Window Maker Live for Pinebook Pro vajak 9 6,239 05-20-2026, 06:55 AM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 14,075 08-09-2025, 06:53 AM
Last Post: Sb2024
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 8 18,498 06-26-2025, 09:20 PM
Last Post: reukiodo
  Pinebook pro won't boot after bootloader installation jwensouls 4 8,445 08-21-2024, 04:17 AM
  Official Debian support moonwalkers 64 121,573 07-08-2024, 01:40 PM
Last Post: Humid Stylus
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 4,642 05-31-2024, 09:42 AM
Last Post: SynthGal
  Pinebook Pro upgrading from the factory image yamsoup 12 17,404 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,179 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,392 12-11-2023, 03:47 AM
Last Post: calinb
