Crippling noise from inside pinecil during a few minutes high power soldering.
Ahoj,
I just had a "high power" soldering job with my Pinecil V2 (power supply: 65W USB C PD; soldering task: Thin steel surface) where I had the pinecil set to maximum temperature and constantliy heating the piece where I wanted to solder.
After some time (2 minutes or so) I heard some noises from inside the pinecil. It did sound a bit crippling, like boiling stuff escaping some enclosure, or so.
I immediately disconnected power supply.
Outside of the pinecil, I felt not anywhere hotness; after disassembling (which took some time where parts can cool down) neither.
Has anyone observed similar things? Is the Pinecil safe to use long time at high power (will safe-protect if too long)? Any thoughts on what I have observed?
I now did re-test without or with thermal load, and in both cases there are two types of noises:
* Some regular noise which sounds like coming from driving the power output FET (PWM noise),
* rarely, some irregular noise as described above.
The second one _may_ also be some noise related to regular operation, emitted by the small inductor on the PCB, but I cannot discern.
Does the regulation sometimes involve "very irregular" pulses through the power FET/ the inductor?
Regards!
(10-03-2023, 05:51 AM)dreieck Wrote: I just had a "high power" soldering job with my Pinecil V2 (power supply: 65W USB C PD; soldering task: Thin steel surface) where I had the pinecil set to maximum temperature and constantliy heating the piece where I wanted to solder.
in my case I can here some very weak noise in the Pinecil V2, but it is very low level, but I think it is PWM. In noisy room its can not be heard.
If nothing is heating on the PCB during this noise, so should be fine. If possible, try another PD supply.
(10-03-2023, 05:51 AM)dreieck Wrote: Ahoj,
I now did re-test without or with thermal load, and in both cases there are two types of noises: dinosaur game
Regards!
The noises you heard from inside the Pinecil during your high-power soldering job could be attributed to the normal operation of the device. When a soldering iron is operating at its maximum temperature and providing constant heat to a piece, it can generate some audible noises, including PWM noise from driving the power output FET. Additionally, the irregular noise you mentioned could potentially be related to the small inductor on the PCB. While it's difficult to discern the exact cause without further investigation, it's worth noting that these noises might be within the normal range of operation for the Pinecil. However, if you have concerns about the safety of using the Pinecil for extended periods at high power, it's advisable to reach out to the manufacturer or consult the product documentation for guidance on its recommended usage and any built-in safety mechanisms.
Mine still works fine, and having also read other reports I assume that the "crippling" noise also comes from electromechanics in the inductor, by regulating power.
  Pinecil V2 doesn’t power on under any circumstances BigCarrotLeaf 1 2,103 03-28-2026, 02:37 AM
Last Post: Juptin
  Pinecil v2: Use car battery for power? FZB 0 358 03-02-2026, 09:56 AM
Last Post: FZB
  Is Vector3d.shop a legitimate pinecil reseller? jamespo 0 779 12-03-2025, 07:40 AM
Last Post: jamespo
  Minimum temperature Pinecil pschalkwijk 1 976 10-16-2025, 10:40 PM
  Pinecil v2 not reaching 20v … Escape75 0 4,247 09-23-2025, 09:25 PM
Last Post: Escape75
  Pinecil v2 tip screw temperature Minuen 0 8,952 06-23-2025, 06:38 AM
Last Post: Minuen
  Pinecil v2 issue autumnharris 0 1,303 05-15-2025, 01:35 AM
Last Post: autumnharris
  Pinecil constantly cutting out WroughtIron 1 2,896 01-16-2025, 02:20 AM
Last Post: D4veC4rter
Exclamation Pinecil is working with 5v but nothing else!! MizterPink 1 1,996 01-07-2025, 03:59 PM
Last Post: MizterPink
  Pinepower suitable for an s23 (and a pinecil) its_lieseeeee 0 1,520 12-09-2024, 01:41 PM
Last Post: its_lieseeeee
