PinePhone Pro not booting (Cap error!, pctl timeout)
today I tried to boot my PinePhone Pro, but it doesn't boot.
- Battery is charged (used external Charger, bought new battery)
- I can connect it to my PC and see the device in MASKROM mode
- no led or vibration is noticable
Trying to boot the phone connected with UART got me following lines.
U-Boot TPL 2021.10 (Oct 04 2021 - 15:09:26) Channel 0: col error Cap error! Channel 1: LPDDR4, 50MHz BW=32 Col=10 Bk=8 CS0 Row=15 CS1 Row=15 CS=2 Die BW=16 Size=2048MB 256B stride lpddr4_set_ctl: channel 0 training failed! lpddr4_set_rate: change freq to 400000000 mhz 0, 1 read_mr: pctl timeout!
Do someone have seen this, or maybe a solution to this problem?
Hi jealda,
I'm seeing exactly the same here; did you manage to fix it?
I've tried to install Tow-Boot from sdcard and pressing the RE button and still getting the same:
Tow-Boot TPL 2022.07 Channel 0: LPDDR4, 50MHz BW=32 Col=10 Bk=8 CS0 Row=15 CS1 Row=15 CS=2 Die BW=16 Size=2048MB Channel 1: LPDDR4, 50MHz BW=32 Col=10 Bk=8 CS0 Row=15 CS=1 Die BW=16 Size=1024MB 256B stride lpddr4_set_ctl: channel 0 training failed! lpddr4_set_rate: change freq to 400000000 mhz 0, 1 read_mr: pctl timeout!
Damn, looks like I too, joined the club of people with broken DRAM.
Booting on SPI: rk2aw + U-Boot's TPL on secondary:
rk2aw: booted version RK3399/pinephone-pro/2023-08-02/18:13:28 rk2aw: Booted from source 3 (SPI NOR) block=0x00 rk2aw: Will try booting boot block 0x01 on SPI NOR U-Boot TPL 2023.07-rc6-megi-ppp-00050-g222aa75acee7-dirty (Aug 03 2023 - 15:09:37) lpddr4_set_ctl: channel 0 training failed!
Booting from TowBoot on SD Card:
SPI rk2aw + Rockchip's ddrbin on Primary:
rk2aw: booted version RK3399/pinephone-pro/2023-08-02/18:13:28 rk2aw: Booted from source 3 (SPI NOR) block=0x00 rk2aw: Will try booting boot block 0x07 on SPI NOR DDR Version 1.30 20230417 In channel 0 CS = 0 MR0=0x98 MR4=0x3 MR5=0xFF MR8=0x8 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 CS = 1 MR0=0x18 MR4=0x3 MR5=0xFF MR8=0x8 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 1 CS = 0 MR0=0x98 MR4=0x1 MR5=0xFF MR8=0x8 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 0 training failed! channel 1 training pass! change freq to 416MHz 0,1 Channel 0: LPDDR4,416MHz Col error!!! Cap error! Channel 1: LPDDR4,416MHz Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB no stride channel 1 CS = 0 MR0=0x98 MR4=0x1 MR5=0xFF MR8=0x8 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 1 training pass!
Damn.
(07-11-2023, 10:50 AM)jealda Wrote: Do someone have seen this, or maybe a solution to this problem?
So, yes. I've joined the club of people seeing that.
(10-29-2023, 03:48 PM)jjardon Wrote: I'm seeing exactly the same here; did you manage to fix it?
Given that it's complaining of not being able to initialize a RAM channel, I'm starting to suspect that "managing to fix it" involves either a chip reflow workstation (for the DIY solution)  (Which is way beyond my reach) or a main board replacement (which is expensive).
Bug PinePhone modem keeps "disappearing" Kevin Kofler 21 24,178 09-11-2026, 09:18 AM
Last Post: idice
  Pinephone + Keyboard for sale, little use ruemoo 18 16,068 08-23-2026, 12:17 AM
Last Post: Nambo
  Pinephone - broken power button rorus 14 26,622 05-17-2026, 03:52 PM
Last Post: EuvzO8
  PinePhone 16 GB – Free to a Good Home Anna 2 2,694 01-20-2026, 01:43 PM
Last Post: Anna
Sad PinePhone USB-C port and audio jack failure Kevin Kofler 4 9,177 12-11-2025, 08:57 AM
Last Post: jakfish
  Recycling pinephone as home server mdk 6 4,767 12-01-2025, 02:57 AM
Last Post: mdk
  PinePhone, PinePhone Pro, Keyboard/Accessories for sale brb78 5 3,762 11-30-2025, 05:45 AM
  Modem Issues with the Pinephone Temmie19 5 7,353 07-02-2025, 12:50 PM
Question Third-party cheap touchscreen/LCD for the Pinephone - lost knowledge? mikeb 2 5,467 06-21-2025, 05:19 PM
Last Post: mikeb
  Pinephone not booting sd card... bruv 1 4,004 03-25-2025, 08:51 PM
