Pinephone not booting sd card...
I am on pinephone and am trying to install pmOS to the emmc but when I try to boot to jumpdrive (on a sd card) the led flashes green and doesn't go to jumpdrive.
What Jumpdrive image are you using? Make sure you use the normal Pinephone one, not the "pinephone-charging" one that only does charging (not jump drive mode) and is designed as a last resort if the battery is so low that normal operating systems will not boot. Also make sure that you flashed the image correctly to the microSD card (as a raw image using dd or a GUI frontend to it, not as a regular file – and yes, that will overwrite anything that was previously on the microSD card).
Bug PinePhone modem keeps "disappearing" Kevin Kofler 21 23,638 09-11-2026, 09:18 AM
Last Post: idice
  Pinephone + Keyboard for sale, little use ruemoo 18 15,603 08-23-2026, 12:17 AM
Last Post: Nambo
  Pinephone - broken power button rorus 14 26,208 05-17-2026, 03:52 PM
Last Post: EuvzO8
  PinePhone 16 GB – Free to a Good Home Anna 2 2,572 01-20-2026, 01:43 PM
Last Post: Anna
Sad PinePhone USB-C port and audio jack failure Kevin Kofler 4 9,018 12-11-2025, 08:57 AM
Last Post: jakfish
  Recycling pinephone as home server mdk 6 4,529 12-01-2025, 02:57 AM
Last Post: mdk
  PinePhone, PinePhone Pro, Keyboard/Accessories for sale brb78 5 3,597 11-30-2025, 05:45 AM
  Modem Issues with the Pinephone Temmie19 5 7,111 07-02-2025, 12:50 PM
Question Third-party cheap touchscreen/LCD for the Pinephone - lost knowledge? mikeb 2 5,294 06-21-2025, 05:19 PM
Last Post: mikeb
  various tricks to open the pinephone shengchieh 3 6,308 09-16-2024, 03:42 AM
