Using Signal on PinePhone in mid-2023?
#21
(06-20-2023, 02:00 AM)dante404 Wrote: @zetabeta & @Pelecanus :
I meant updates of the signal-desktop-app (sorry for not beeing precise on this), but everything you said about signal-cli is of course relevant and helpful as well, thanks! Smile
The answer is similar - always have a backup, then just update / download and install the new version Smile
OK, thank you very much! Smile
Using encrypted Mobian (bookworm) on pmOS CE Convergence PinePhone (3GB/32GB) as Daily Driver, and Beta Edition Convergence PinePhone (3GB/32GB) with encrypted Mobian (bookworm) as Backup device.
Another short question to all "Signal-Desktop on PinePhone"-users here Wink :
Do you also have the problem that you can't open/view (or save)... pictures someone sent you?
I see a blurred image in the chat, with the round "arrow down" icon/button on top in the middle, the icon reacts when touched (short circle animation) but nothing happens in the end. Can't see what relatives and friends have sent me (via their regular Signal App for Android/iOS). Sad
(06-20-2023, 07:28 AM)dante404 Wrote: Another short question to all "Signal-Desktop on PinePhone"-users here Wink :
It works for me. The image isn't blurred and I can save the image. I'm using Signal Desktop v6.20.2 from undef1 repository.
Using the same version from the same repo. Strange. Did you compile it yourself? (I used the .deb)
Which OS do you use on your PinePhone if I may ask? (I'm using Mobian, perhaps there's the difference?)
(06-21-2023, 12:02 AM)dante404 Wrote: Using the same version from the same repo. Strange. Did you compile it yourself? (I used the .deb)
I use the .tar.xz (reason is that there was no .deb when I first installed it). I wonder if this can make a difference?
And Mobian on my PinePhone, too.
(06-21-2023, 07:58 AM)Pelecanus Wrote: I use the .tar.xz (reason is that there was no .deb when I first installed it). I wonder if this can make a difference?
It shouldn't I think... but I don't see any other possible difference.  Huh
Thanks for the reply/info!!!
(Sadly my Axolotl got deregistered (and registering doesn't work anymore) when registering singal-cli, now I can have groups and can add new contacts but don't see images anymore... damn  Undecided   )
(06-21-2023, 08:46 AM)dante404 Wrote: (Sadly my Axolotl got deregistered (and registering doesn't work anymore) when registering singal-cli, now I can have groups and can add new contacts but don't see images anymore... damn  Undecided   )
Maybe a workaround is to use the signal-cli?:
signal-cli -a <your phone number> receive
It stores pictures in `~/.local/share/signal-cli/attachments/`.
(06-21-2023, 09:32 AM)Pelecanus Wrote: Maybe a workaround is to use the signal-cli?:
Yes, would be an option - Better than nothing I guess Wink - Thank you!
(Used signal-cli just on my Linux-Desktop-PC to activate the Client on the PinePhone, so I guess I will have to get it on the PinePhone as well...)
@zetabeta & @shulamy:
Because it seems not to be a general problem according to Pelecanus - Does your "Signal-Desktop-App on PinePhone" show images someone sent you? Huh
 i have to check it - next week
ezik
  Difficulty with openSUSE Tumbleweed Install PinePhone Beta danm1988 0 198 11-17-2025, 07:49 AM
Last Post: danm1988
  Movuan distribution for PinePhone merom 5 4,907 07-27-2025, 05:01 PM
Last Post: merom
  baremetal via Zig on PinePhone - JumpDrive help please WhiteHexagon 1 3,176 07-07-2025, 10:33 AM
Last Post: WhiteHexagon
  Latest firmware for PinePhone modem! Subsentient 105 203,991 02-02-2025, 08:47 PM
Last Post: bacydentir85
  Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit] acid andy 40 55,675 12-28-2024, 12:19 AM
  Office applications for the Pinephone Peter Gamma 2 4,418 09-05-2024, 09:22 AM
Last Post: Peter Gamma
  Struggle to install LibreOffice on the PinePhone Peter Gamma 50 60,791 07-26-2024, 10:35 PM
  Why does Pine64 sabotage office on the Pinephone? Peter Gamma 5 5,748 07-04-2024, 07:34 AM
  Which word processor to choose for the Pinephone? Peter Gamma 16 15,498 06-22-2024, 07:28 AM
  Samba share on the Pinephone? Peter Gamma 0 3,884 06-16-2024, 10:26 PM
