PinePower USB-C ports dead
I have two PinePower 120W desktop power supplies, both have lost the USB-C ports.  No matter what is plugged in, the display reads 0 volts.  I have check the end devices and the cables with other chargers, the cables and end devices work fine.  I had previously charged the same devices with these PonePower supplies.
Judging from other messages, I am starting to get the impression something is defective with the USB-C port, does anyone have a fix?
Mike
(01-13-2023, 11:58 AM)nbxmike Wrote: I have two PinePower 120W desktop power supplies, both have lost the USB-C ports.  No matter what is plugged in, the display reads 0 volts.  I have check the end devices and the cables with other chargers, the cables and end devices work fine.  I had previously charged the same devices with these PonePower supplies.
Mike
If the hardware is defective I would suggest to open a ticket under https://support.pine64.org
  Firmware Update for PinePower Desktop Power Cycling Issue TimothyRodriguez 1 3,074 05-03-2024, 12:53 AM
Last Post: Pavlos1
  PinePower 120w On/Off Switch rohtua 7 11,681 08-01-2023, 05:36 PM
Last Post: Callabra
Question How many SPI ports/buses are broken out/available on SOQUARTZ? gogerriko 5 7,703 04-05-2023, 10:34 AM
Last Post: gogerriko
  Issues with PinePower Desktop superkamiguru 0 2,176 10-24-2022, 07:43 AM
Last Post: superkamiguru
  PinePower 65w - DoA or am I doing it wrong? CampGareth 10 16,205 10-04-2022, 09:02 AM
Last Post: hobbitus
  PinePower 120W Screen Issues t-3 3 5,146 09-26-2022, 05:14 PM
  on pinepower, pinecil stopped working.. sanderboer 1 3,528 09-23-2022, 03:47 AM
  PinePower Desktop USB-C port dead qeek 3 5,521 08-29-2022, 12:33 AM
Last Post: gravedigger
  PinePower USBench concept: Usb C universal/lab power supply (=48V5A PD 3.1 trigger) ijsbeer 3 7,704 04-16-2022, 04:59 PM
Last Post: ijsbeer
  PinePower 65W GaN Charger, bad EU addapter talpa 1 3,899 11-20-2021, 05:21 PM
Last Post: bharwargl
