Rock64 Debian 11 (Bullseye) install problem
Lightbulb
For all of you who struggle to install Debian onto your Rock64, I've made a how to guide for this.
A pdf for downloading and safe keeping / later use is in that repo as well.
@ju0n this is a revised version which just uses the images and u-boot directly from Debian.
Awesome!
Thanks a lot
(12-11-2022, 08:31 AM)as365n4 Wrote: For all of you who struggle to install Debian onto your Rock64, I've made a how to guide for this.
Are we saying, then, the posted instructions have a major flaw?
(02-24-2023, 06:17 PM)Flagtrax Wrote: Are we saying, then,  the posted instructions have a major flaw?
I would not say major flaw, but software matures and evolves over time. ;-)
And using the Debian Installer is the most efficient way right now, even though it can't install u-boot for some reason.
I think there was some intention to point this out on the wiki:
"Remember to leave some space before your first partition for u-boot! You can do this by creating a 32M size unused partition at the start of the device."
But it's unclear when or how to do that, simply performing manual partitioning in the (bookworm) installer, and leaving the initial fat partition alone is enough for the debian installer to work as expected. When I can figure out how to reset my wiki password I'll try to tweak that assuming no one else does first.
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 12 17,396 03-07-2026, 11:04 AM
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 567 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 4,962 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 10,943 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 2,793 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 2,908 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  problem with debian emmc boot G4zCDzWb 10 11,093 11-01-2024, 04:32 PM
Last Post: bits
  Debian installation via sd card oaFJSADBKV 0 2,083 10-12-2024, 10:24 AM
Last Post: oaFJSADBKV
  arch rock64 does not boot nemnob 1 4,096 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  DietPi OS for ROCK64 MichaIng 42 80,641 09-01-2024, 06:43 AM
Last Post: RaymondDay
