!! Pinecil is dead after 3 times using it, don't buy this crap...
Hi
I bought a Pinecil64 after seeing JB's video...
After I received it, it worked 3-4 times, and the same day it died: No more screen, no reaction when I plug various LiPo battery or USB, doesn't heat up...
The only thing that work is when I plug to my PC I still can uptade it lmao
That's annoying to have bought such a bad product...
Hi, does the support solved your problem?
In this scenario is any chance to see a log of the operating system, to check what is wrong?
(04-22-2022, 06:58 AM)bbeeast Wrote: Hi
Which website did you get Pinecil from and what color is it? First we need to figure out if you have a real Pinecil or bought from Aliexpress a fake copy.
Come to the live Pine64 Pinecil  discord chat volunteers might help you diagnose it.  Not enough details here,  like exactly which cable was used and which charger type (what are specs on charger).
 I always try to use a USB-C  charger first PD65W 20V.
Also depending on who you bought it from contact support for that seller  as they might be able to exchange it depending on circumstance.
Join the Pinecil discord chat though,   as volunteers can help you through a series of test to do.  Link to live chat is in the  Pinecil Wiki  page (community chat).
  pinecil v2 dosent negotiate power moses 0 344 07-07-2026, 07:28 AM
Last Post: moses
  Pinecil low temp mods? davidcoley 0 493 06-21-2026, 02:53 AM
Last Post: davidcoley
  my pinecil v2 is not working jagrav 0 901 04-17-2026, 06:28 AM
Last Post: jagrav
  Pinecil V2 doesn’t power on under any circumstances BigCarrotLeaf 1 2,869 03-28-2026, 02:37 AM
Last Post: Juptin
  Pinecil v2: Use car battery for power? FZB 0 896 03-02-2026, 09:56 AM
Last Post: FZB
  Is Vector3d.shop a legitimate pinecil reseller? jamespo 0 1,296 12-03-2025, 07:40 AM
Last Post: jamespo
  Minimum temperature Pinecil pschalkwijk 1 1,592 10-16-2025, 10:40 PM
  Pinecil v2 not reaching 20v … Escape75 0 4,671 09-23-2025, 09:25 PM
Last Post: Escape75
  Pinecil v2 tip screw temperature Minuen 0 9,485 06-23-2025, 06:38 AM
Last Post: Minuen
  Crippling noise from inside pinecil during a few minutes high power soldering. dreieck 3 5,845 05-15-2025, 10:41 AM
Last Post: dreieck
